POV-Ray : Newsgroups : povray.advanced-users : MegaPovPlus & Glow syntax Server Time
30 Sep 2024 06:19:48 EDT (-0400)
  MegaPovPlus & Glow syntax (Message 1 to 6 of 6)
Subject: MegaPovPlus & Glow syntax
Date: 21 Sep 2000 04:54:28
Message: <39c9ccc4@news.povray.org>
Hi, hope someone can help me with MegaPovPlus.
Downloaded version 0.5a03.0 plus demo files and Docs (Windows version).
 Liked the Glow effects but very little in docs about the syntax.
 More or less figured it out from examples but then I got latest version 3.2
and keep getting parse errors when try to include Glow.
Has the syntax changed, or is Glow no longer supported?
If it's changed please point me in right direction  either examples or
better still a full
description of the syntax.
Thanks in advance,    Torchy
Subject: Re: MegaPovPlus & Glow syntax
Date: 21 Sep 2000 05:20:38
Message: <39C9D2A2.1071287F@hotmail.com>
> better still a full
Chris has changed the syntax & updated the docs, but not the demo scenes
His patch is now at MegaPOV0.5aPlus0.3.2
see http://homepage.mac.com/chrishuff/povpatch.html
BTW there have been some amazing examples in p.b.i & p.b.a
Bye
Pabs
Date: 21 Sep 2000 05:36:43
Message: <39c9d6ab@news.povray.org>
Thanks for very speedy reply.
I have MegaPOV0.5aPlus0.3.2 & 'updated' docs but they're the same as 0.3.0
docs
and are about the Particle system(s) *nothing* about Glow unfortunately!
I'll download generic source for latest version & see if I can figure out
syntax for Glow from that.
Meanwhile I'll keep an eye out in here & unofficial_patches for anything on
Glow.
Torchy.
Date: 21 Sep 2000 06:05:27
Message: <39C9DD7A.CEFDD22C@yahoo.com>
one of the artivles in one of these groups explicitly shows how to
convert an old syntax glow to a new syntax glow.  look around and you
should find it.  no need to go through the source code.
> docs
> Glow.
> Torchy.
Date: 21 Sep 2000 07:12:49
Message: <chrishuff-C5B342.06145321092000@news.povray.org>
In article <39c9d6ab@news.povray.org>, "Peter Meekin"
> 0.3.0 docs and are about the Particle system(s) *nothing* about Glow
> unfortunately!
The zip file containing the documentation *does* contain docs for the
glow effect, including a complete syntax description. You are looking at
"Particles.html" and "particle_system docs", try "Documentation"
instead. If you still can't find it:
Glow effect:
glow {
    location LOCATION
    size FLOAT_SIZE
    radius FLOAT_RADIUS
    color COLOR
    fade_power FLOAT_POWER
    type |0|1|2|3|
    WARPS
    TRANSFORMS
This makes a fast-rendering glow effect. It is based on the light source
glow effect from POV-AFX, written by Marcos Fajardo, but has been
heavily modified. You can specify glows individually, or attached to a
light_source. If created in a light source, they will be automatically
initialized with the light's position and color(though transforming the
light source will not give the expected result).
The "size" keyword adjusts the scale of the glow effect. It is not an
absolute size, just a scaling amount(because some glows are infinite).
It does not quite work properly yet, it causes strange effects with
changing distances of objects behind the glow.
The "radius" keyword specifies a clipping radius confining the glow to a
circular area perpendicular to the ray. If the glow is still visible at
this radius, it will make a sudden transition.
The "fade_power" keyword allows you to provide an exponent to adjust the
falloff with.
Type 2 and 3 glows are not completely implemented yet, but 2 will
simulate a sphere with constant density, and 3 will be based on the
exp() function.
Oh, and there is one error here: type 2 is cosine falloff, not
spherical, which will be type 4.
Christopher James Huff
Date: 21 Sep 2000 07:26:58
Message: <39c9f082@news.povray.org>
Thanks Chris!
It was my mistake,  maybe next time I'll read *everything* before opening my
mouth. <G>
Look forward to getting to grips with more of the great features you've
added to an already
outstanding program.
Peter (aka Torchy)
