POV-Ray : Newsgroups : povray.advanced-users : UV Coordinates? Server Time
24 Feb 2025 01:36:41 EST (-0500)
  UV Coordinates? (Message 1 to 3 of 3)
Subject: UV Coordinates?
Date: 2 Sep 2000 09:54:35
Message: <39b1069b$1@news.povray.org>
Hi everyone,
I'm fairly new at povray, but they tell me this is an advanced question:
Can I specify UV texture coordinates on a triangle?
I come from an OpenGL background, where a triangle's corners are specified
x,y,z, u,v... where u and v are the coordinates inside the texture to map to
each corner.
Is there an equivalent way to do this in povray?  Speed is not an issue... I
just need the functionality.
So again: When I put a triangle down, is there any way to say what texture
coordinate goes at each corner? I'd even be content to make a 'mesh' of one
triangle, if it would work.
Thanks!
Subject: Re: UV Coordinates?
Date: 2 Sep 2000 13:42:15
Message: <chrishuff-04CA34.12435302092000@news.povray.org>
In article <39b1069b$1@news.povray.org>, "John Raptis"
> specified x,y,z, u,v... where u and v are the coordinates inside the
> texture to map to each corner.
> issue... I just need the functionality.
> texture coordinate goes at each corner? I'd even be content to make a
> 'mesh' of one triangle, if it would work.
Standard POV-Ray does not have UV-mapping. However, there is a patch for
UV mapping triangles, patches, meshes, and some other objects, and it is
included in MegaPOV:
http://nathan.kopp.com/patched.htm
I think there is also a macro somewhere for "UV-mapping" individual
triangles in official POV-Ray, but I don't know any more about it except
that it was more memory consuming than the patch. POV-Ray 3.5, which
should be released sometime this year, will probably have UV-mapping.
Christopher James Huff
Date: 3 Sep 2000 01:38:36
Message: <39b1e3dc@news.povray.org>
It wasn't until I read your reply, Chris, that I remembered I'd actually
created a macro for this!  Of course, it does use more memory than the
"built-in" UV-mapping of MegaPOV, but it will allow you to render UV mapped
triangles in official POV-Ray 3.1.  You can download the macro from the
Other Include Files page at http://www.geocities.com/ccolefax.
