POV-Ray : Newsgroups : povray.advanced-users : #while loop help Server Time
24 Feb 2025 01:00:21 EST (-0500)
  #while loop help (Message 1 to 10 of 14)
Subject: #while loop help
Date: 1 Sep 2000 18:04:46
Message: <39b027fe$1@news.povray.org>
Hello all...:)
I am hoping this is the proper newsgroup (my first post,
at that.
I need a #while loop that places an object in a 2d grid
with say 5 objects in a row and 5 objects per column.
X  X  X  X  X
X  X  X  X  X
X  X  X  X  X
X  X  X  X  X
X  X  X  X  X
Essentially, I am placing a copy of an object 25 times
in a 5x5 grid.  However, the code below does not work:
For the keen ones amongst you, I am trying to create a
hexagonally tiled floor with the hexagons rounded at the
edges and a small amount of grout between each
hexagon.
David Fontaine has helped me greatly in getting me to
this point, but getting the hexagons to tile correctly has
been a major headache.  I suspect my "understanding"
of the #while - #end loops is not fully correct, although
I don't know where I am going wrong looking at code
and the help docs. :)
Any help is greatly appreciated. :)
Thanks!
Todd
tta### [at] netrelatedcom
        location <0,10,0.05>
        look_at <0,0,0>
        rotate <0,0,0>}
light_source { <4,4,-6> color rgb <1,1,1>}
#declare Tile = union {
  union{
   intersection {
      cylinder { <-.5,0,sqrt(3)/2>,<.5,0,sqrt(3)/2>,.1 }
      plane { x,0 rotate 30.01*y }
      plane { -x,0 rotate -30.01*y }
   sphere{<.5,0,sqrt(3)/2>,.1}
  union{
   intersection {
      rotate 60*y
   sphere{<.5,0,sqrt(3)/2>,.1 rotate 60*y}
on{
   intersection {
      rotate 120*y
   sphere{<.5,0,sqrt(3)/2>,.1 rotate 120*y}
  union{
   intersection {
      rotate 180*y
,.1 rotate 180*y}
  union{
   intersection {
      rotate 240*y
   sphere{<.5,0,sqrt(3)/2>,.1 rotate 240*y}
  union{
   intersection {
      rotate 300*y
   sphere{<.5,0,sqrt(3)/2>,.1 rotate 300*y}
   prism { -.1,.1,7 <-1,0>,<-.5,sqrt(3)/2>,<.5,sqrt(3)/2>,
           <1,0>,<.5,-sqrt(3)/2>,<-.5,-sqrt(3)/2>,<-1,0> }
  pigment { color rgb<0,0,1> }
  finish { ambient .6 metallic reflection .6}
#declare grout_size=.05;
#declare TileWidth=2;
#declare RoundEdgeWidth=.05;
#declare Count1=-25;
#declare Count2=-25;
#while (Count1<=25)
 #while (Count2<=25)
  object { Tile
   translate
<Count1*(1.5*TileWidth+2*grout_size+2*RoundEdgeWidth),0,Count2*(sqrt(3)+2*gr
out_size+2*RoundEdgeWidth)>
  #declare Count2=Count2+1;
 #declare Count1=Count1+1;
union {
 plane {y,0
  pigment { color rgb<1,1,1> }
 object
  Tile
Subject: Re: #while loop help
Date: 1 Sep 2000 18:10:47
Message: <39b02967@news.povray.org>
You have to reset count2 within the first #while-loop. It is at 26 after the
first loop an remains there.
Todd Taylor schrieb in Nachricht <39b027fe$1@news.povray.org>...
>#while (Count1<=25)
> #while (Count2<=25)
>  object { Tile
>   translate
r
> #end
>#end
Date: 3 Sep 2000 14:27:55
Message: <39b2982b@news.povray.org>
Marc-Hendrik Bremer <Mar### [at] t-onlinede> wrote:
: You have to reset count2 within the first #while-loop.
  Loops are so often misunderstood and misused that I should make an entry
about them in the VFAQ. I just don't know where to start and what to ask.
  I'll think about something.
Date: 3 Sep 2000 16:10:41
Message: <8FA4E57A0seed7@204.213.191.228>
>  entry about them in the VFAQ. I just don't know where to start and what
>  to ask.
Think about it with an absolute non-programmer mind.
When I first encouterd a loop, it took men an hour to realize that I had
to do the incrementing myself. I expected it to be automatic.
It took me a day to figure out I had to reset the counter of the inner
loop myself. For me it seemed very logical that once I had gone through
the loop the counter would not exist anymore until the loop was enterd
again.
Now that I'm slowly learning some python, i did it wrong twice in pov. In
python it indeed is all (more or less) automatic.
while i in range(25):
  while j in range(25):
    do some tings here inside the loops
coninue program outside the loop
Ingo
Date: 3 Sep 2000 16:42:57
Message: <39b2b7d1$1@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:8FA4E57A0seed7@204.213.191.228...
|     do some things here inside the loops
| continue program outside the loop
That looks awfully easy.  Why the word "in" though?  Just so you don't think
it's too simple?
Date: 3 Sep 2000 17:08:25
Message: <chrishuff-F3A9F1.16100403092000@news.povray.org>
In article <8FA4E57A0seed7@204.213.191.228>, ing### [at] homenl (ingo)
Easier said than done.
This is done for flexibility and ease of coding...a variable is just a
variable, whether you use it as a counter or not, how is POV supposed to
know it needs to be incremented when the loop ends? Also, there are
times when you want to increment the loop by a different amount, and
times when you don't even want to use an incrementing variable for
control. Loops aren't only used for making several copies of an object.
> again.
This could make sense if you created the variable inside the outer loop
in many other languages, but if you create it outside both loops, why
would you expect it to be destroyed when the outer one loops back to
it's start?
Anyway, POV seems to only have variables local to files and macros. With
a separate keyword for modifying variables, like what my #set patch
implements, it would be possible to use variables local to any block,
like #if statements and #while loops, but I don't expect that to happen
for a while, if ever.
Christopher James Huff
Date: 4 Sep 2000 09:21:31
Message: <39b3a1da@news.povray.org>
Ok, I added an entry about the while loops and made a page about it:
http://iki.fi/warp/povVFAQ/whileloops.html
Date: 4 Sep 2000 11:17:28
Message: <8FA5ADEABseed7@204.213.191.228>
That why I like it.
>think it's too simple?
Don't ask me...
Ingo
Date: 4 Sep 2000 11:20:07
Message: <8FA5B4D28seed7@204.213.191.228>
excellent!
Ingo
Date: 4 Sep 2000 11:29:12
Message: <8FA5BA95Bseed7@204.213.191.228>
Chris Huff wrote:
<snip>
Neither do I, nor do I want it. It was just to illustrate how "illogic" a
total non-programmer can think(me, two years ago, after only two days
playing with POV).
Compare it to chess. You can learn anybody the moves each piece can make,
but he'll only be able to play chess after he grasps the concept behind
the game.
Ingo
