POV-Ray : Newsgroups : povray.advanced-users : #while loop help Server Time
18 May 2026 08:58:23 EDT (-0400)
  #while loop help (Message 11 to 14 of 14)
Subject: Re: #while loop help
Date: 4 Sep 2000 18:01:01
Message: <slrn8r847i.jut.hjp-usenet@teal.h.hjp.at>
On 3 Sep 2000 16:10:41 -0400, ingo wrote:
>Think about it with an absolute non-programmer mind.
>When I first encouterd a loop, it took men an hour to realize that I had
>to do the incrementing myself. I expected it to be automatic.
>It took me a day to figure out I had to reset the counter of the inner
>loop myself. For me it seemed very logical that once I had gone through
>the loop the counter would not exist anymore until the loop was enterd
>again.
In most languages this is the difference between a while loop and a for
loop. The while loop is repeated while a certain condition is true. The
for loop is repeated for a set of values.
For example, in
#local a = 0;
#while (a < 20)
You can do everything with a inside the loop, as long as you stay below
20. You don't just have to increase it by 1 with every cycle. You can
increase it by 0.1, by a random value, you can decrease it again, or you
can compute it as a function of some other variable.
On the other hand, Pascal (for example) has a for loop:
var i: integer;
begin
    i := 5;
    for i := 1 to 20
    do
	println(i);
    done
    println(i);		{ ??? }
end;
will print the values from 1 to 20. No need to increment manually,
because the loop always increments the count by 1. In fact you are not
allowed to assign a new value to i inside the loop, and it isn't
specified what the println after the loop will print. 5, 20, or 21 would
be values you could expect (if you know a little bit about how a pascal
compiler works), but it could also be some completely random value.
So the for loop is simpler, but less flexible. Because you can always
rewrite a for loop as a while loop, but not vice versa, Povray only has
a while loop.
	hp
   _  | Peter J. Holzer    | Nicht an Tueren mangelt es,
|_|_) | Sysadmin WSR       | sondern an der Einrichtung (aka Content).
| |   | hjp### [at] wsracat      |    -- Ale### [at] univieacat
__/   | http://www.hjp.at/ |       zum Thema Portale in at.linux
Date: 5 Sep 2000 10:45:27
Message: <39b50707@news.povray.org>
I just added more stuff at the end of the document, if someone is interested.
Date: 5 Sep 2000 18:55:00
Message: <39B57A0C.D636AC0F@tiac.net>
Yours looks more in-depth but Sonya Roberts has a #while tutorial
at the Rendering Times...
http://www.spake.org/rtimes/article/povindx.htm
Phil
Date: 5 Sep 2000 20:54:28
Message: <39B59562.7B9464E3@pacbell.net>
Were it not for that tutorial I never would have understood #while loops.
