POV-Ray : Newsgroups : povray.advanced-users : Variations on a Theme Server Time
30 Sep 2024 06:14:48 EDT (-0400)
  Variations on a Theme (Message 1 to 4 of 4)
Subject: Variations on a Theme
Date: 1 Sep 2000 14:57:32
Message: <39affc1c$1@news.povray.org>
I am building a scene where there are a large number of 'nearly identical'
items.
The only difference is that each item has a different number or letter
painted on its side.
(i.e.. like a set of one color pool balls)
Because the number of objects is quite large, I would like to use a standard
object approach and just do a location transform plus adding the number in
the final .pov file.
Has anybody done anything like this ?
David
Subject: Re: Variations on a Theme
Date: 1 Sep 2000 15:03:14
Message: <39affd72$1@news.povray.org>
I don't consider me to be an advanced-user, but couldn't you just #declare
your basic shape and make a union of it together with the textobject for the
number/letter (or what ever you need to make it unique)? The hole union can
then be transformed and both - basic shape plus letter/number - would be
affected.
Marc-Hendrik
David Vincent-Jones schrieb in Nachricht <39affc1c$1@news.povray.org>...
>items.
standard
>David
Date: 1 Sep 2000 16:18:23
Message: <chrishuff-9E0814.15195901092000@news.povray.org>
In article <39affc1c$1@news.povray.org>, "David Vincent-Jones"
> identical' items.
> letter painted on its side. (i.e.. like a set of one color pool
> balls)
> standard object approach and just do a location transform plus adding
> the number in the final .pov file.
The easiest way to do the balls would be to use a texture using an
object pattern with a text object to make the different numbers, but
that requires MegaPOV(in fact, I designed the object pattern with a text
pattern in mind). You might be able to make a macro which just takes a
character and color and produces the appropriate ball by doing CSG
between spheres and text objects, but this is slower and just clumsier.
Christopher James Huff
Date: 1 Sep 2000 16:22:43
Message: <39b01013$1@news.povray.org>
It's been done, yes.  In fact it was pool balls that were done in such away
before that I'm thinking of, but I probably couldn't locate it if I tried.
So....
I'll put an example of what I have done at the povray.text.scene-files
group, look for a Systematic Labeling post there.
I might not have understood completely, you seem to have asked about putting
the number into the pov file name or something.  Maybe not though...
"David Vincent-Jones" <geo### [at] galaxynetcom> wrote in message
news:39affc1c$1@news.povray.org...
