POV-Ray : Newsgroups : povray.advanced-users : photons Server Time
21 Dec 2025 10:48:37 EST (-0500)
  photons (Message 1 to 10 of 20)
Subject: photons
Date: 16 Aug 2000 08:19:20
Message: <399A871D.3F000619@psu.edu>
How can i take a light source and reflect the light off a mirror type
object and get both beams of light (incident and reflected) to show up
in media? I tried using photons and media.... but I cannot seem to get
the reflected light to interact with the media....
Paul Daniel Jones
307 Chandlee Laboratory
Penn State University
814-865-2090
pdj### [at] psuedu
http://research.chem.psu.edu/glassgrp/paul
Subject: Re: photons
Date: 16 Aug 2000 13:35:39
Message: <399ad0eb@news.povray.org>
This is not how raytracing works. You probably want radiosity.
bye,
  Chris
Christian Perle              E-mail:        chr### [at] tu-clausthalde
Am Galgensberg 4             WWW:        http://home.tu-clausthal.de/~incp/
38678 Clausthal/Germany      ComputerGuitarKitesBicyclesBeerPizzaRaytracing
Date: 16 Aug 2000 14:06:32
Message: <chrishuff-3D2EDC.13074216082000@news.povray.org>
In article <399ad0eb@news.povray.org>, Christian Perle
Radiosity doesn't do this type of thing either.
I believe he is asking about the photon mapping patch, which does
simulate this type of effect. However, I haven't looked at the most
recent versions of the patch, so I can't really help with this problem...
Christopher James Huff
Personal: e-mail chr### [at] maccom, Web page http://homepage.mac.com/chrishuff/
TAG: e-mail chr### [at] tagpovrayorg, Web page http://tag.povray.org/
Date: 16 Aug 2000 15:10:22
Message: <399ae71e@news.povray.org>
"Paul Daniel Jones" <pdj### [at] psuedu> wrote in message
news:399A871D.3F000619@psu.edu...
Same thing for me.  I tried and failed at it.  I had used the 'media'
keyword inside the photon block and did everything I could think of.  No
reflected light in the media, only on the walls, etc.  Could still be a
number problem, as in lack of enough sampling and such.  That and the fact
I've used a cylindrical spotlight, although trying with a regular spotlight
or point light source I hadn't had any luck seeing reflected light in the
media either.
Date: 16 Aug 2000 16:00:51
Message: <399AF346.B1BBE5E7@psu.edu>
see Warps image on 3/27/00 in p.b.i......  I can't do this     :-(
> Paul Daniel Jones
> 814-865-2090
> pdj### [at] psuedu
Paul Daniel Jones
814-865-2090
pdj### [at] psuedu
Date: 16 Aug 2000 17:11:05
Message: <399b0369@news.povray.org>
I'm missing Fe. and Mar. here, I was looking for those related postings too.
Warp was faking it with multiple cylinders if IIRC.
news:399AF346.B1BBE5E7@psu.edu...
Date: 16 Aug 2000 18:26:23
Message: <b75mpssrej1ur2jukptiit62v5cjm44hhh@4ax.com>
On Wed, 16 Aug 2000 08:20:45 -0400, Paul Daniel Jones <pdj### [at] psuedu>
Wasn't there something about a bug with cylinder lights and
photons/media? (in MegaPOV, that is)?
Peter Popov ICQ : 15002700
Date: 16 Aug 2000 19:13:53
Message: <399b2031$1@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote in message
news:b75mpssrej1ur2jukptiit62v5cjm44hhh@4ax.com...
I guess cylinder lights don't work perfectly with photons to begin with
somehow.
That's not the trouble,  since I've tried it using a hole in the side of a
box and a point source.  So it's nothing to do with not working with
spotlights either.  Nathan has probably said before that media won't show a
reflected light, just not sure when or where if he did say so.
Date: 16 Aug 2000 22:03:49
Message: <chrishuff-9FE4ED.21050216082000@news.povray.org>
In article <399b2031$1@news.povray.org>, "Bob Hughes"
<per### [at] aolcom?subject=PoV-News:> wrote:
> Nathan has probably said before that media won't show a reflected
Actually, it *will* work. Media interaction is one of the features added
in one of the more recent versions. It takes a lot of computation time
and memory, but it works, and there was a laser-beam scene demonstrating
it. There is also a sample scene demonstrating media-photon
interaction(mediaphot.pov), maybe you should look at it for ideas.
I just am not familiar enough with the most recent version to figure out
the problem.
Date: 17 Aug 2000 07:26:44
Message: <399bcbf4@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-9FE4ED.21050216082000@news.povray.org...
Okay, I got it now, thanks so much for pointing out that sample scene file.
All I had to do is set reflection to on in the sphere and I saw the
spotlight shining back from it.  Great thing.  Now I have gotten a cylinder
spotlight to actually show up too, the weird thing is there wasn't really
any obvious reason for the not-working and working ways.  It's almost
metamorphosing the more I try to use it.  Typical thing because of so many
possible media settings I guess.  I at first even thought it was all because
of the sample file having a 'media on' in the photon block.   Not so.  I
tried with and without and get the laser light reflected in the media.
Curious to say the least.  I'm going to post this test render I have to
p.b.i. in a few minutes so it will prove to others it can be done.
