POV-Ray : Newsgroups : povray.advanced-users : photons Server Time
18 May 2026 08:57:35 EDT (-0400)
  photons (Message 11 to 20 of 20)
Subject: Re: photons
Date: 17 Aug 2000 10:10:06
Message: <399bf23e@news.povray.org>
Bob Hughes <per### [at] aolcom?subject=pov-news:> wrote:
: I'm missing Fe. and Mar. here, I was looking for those related postings too.
: Warp was faking it with multiple cylinders if IIRC.
  FAKING!!! Who do you think I am? Those are TRUE photons. Period :)
  The image can be found here: http://www.cs.tut.fi/~warp/photontest.jpg
  And if you don't believe it's made with photons, here is the proof: The
source code:
#version Unofficial MegaPov 0.5;
#include "textures.inc"
#declare UsePhotons=yes;
global_settings
  max_trace_level 8
#if(UsePhotons)
  photons
  { count 20000
    autostop 0
    media 100
box
{ <-4,-3,-1.5>,<8,3,1.5> hollow
  pigment { rgbt 1 }
  photons { pass_through }
  interior
  { media
    { intervals 10
      scattering { 1, rgb .5 extinction .01 }
      method 3
sphere
{ 0,70 inverse
  pigment
  { bozo color_map { [0 rgb 0][1 rgb <1,.5,0>] }
    scale <5,10,5>
camera
{ location -z*20 look_at 0 angle 35
light_source
{ <50,2,0> 1
  spotlight point_at y*2 radius .5 falloff .6
light_source
{ <100,100,-100>*.3 .8 media_interaction off
#if(UsePhotons)
  photons { reflection off refraction off }
#declare MirrorBox=
union
{ difference
  { box { <-.5,-1.8,-1.8><.1,1.8,1.8> }
    box { <-.1,-1.5,-1.5><.11,1.5,1.5> }
    pigment { DMFWood4 }
  box
  { <-.1,-1.5,-1.5><0,1.5,1.5>
    pigment { rgb 0 }
    finish { reflection 1 diffuse 0 ambient 0 }
#if(UsePhotons)
    photons
    { target
      refraction off
      reflection on
      ignore_photons
object
{ MirrorBox
  rotate z*-45
  translate <-3,2,0>
object
{ MirrorBox
  rotate z*45
  translate <-3,-2,0>
box
{ <-.5,-1.5,-1.5><0,1.5,1.5>
  pigment { Cherry_Wood scale .5  }
  rotate z*180
  translate <5,-2,0>
sphere
{ 0,1.3 scale <.3,1,1>
  pigment { rgbf <.7,.9,1,.9> }
  finish { specular .5 reflection .1 }
  interior { ior 1.5 }
  translate <2,-2,0>
#if(UsePhotons)
    photons
    { target
      refraction on
      reflection on
Date: 17 Aug 2000 11:43:10
Message: <399c080e$1@news.povray.org>
news:399bf23e@news.povray.org...
Ahhh, further proof that my mind is a sieve.  Please excuse my ignorance.  I
was certain you had to resort to using cylinders for media containers for
that image (which I did remember).
Thanks greatly for posting that source.  I suppose the folded overlaps at
the mirrors was fixed by using enough media samples or in some such way?
I'm seeing plenty of change from one render to the next when altering the
intervals and/or samples in the scene file I'm checking all this out with.
Date: 17 Aug 2000 14:04:58
Message: <399C2986.8E71D99E@insectes.net>
I copy-pasted this source and ran it in MegaPOV 0.5, everywhere I expect to see
media, all I get is black
Date: 17 Aug 2000 16:11:15
Message: <399C46E1.9FB01A34@aol.com>
expect to see
Renders fine for me.  Maybe you should check your .ini settings and make
sure you're not using quality 1 or something.
-Mike
Date: 18 Aug 2000 00:59:13
Message: <399CC2DD.25D3B40D@insectes.net>
Believe me, I'm sure ;)
There was nothing specified, which means it should default to 9, which it
does indicate in the messages window, but still it was black. So I tried
putting +Q9 as command line parameter, still black. +Q10, still black.
Anyway, it's not too important.
On an unrelated note, you mentioned that you modified the source code to get
uv_mapping working for type 2 bicubic patches, could you send me the
files?(Actually to someone else ;) I know someone who has successfully
compiled POV (Win) and is willing to try with this modification. If you
agree, I'll let you know his e-mail so you can send it to him directly,
avoiding the middle man :)
Date: 18 Aug 2000 01:22:43
Message: <399CC821.3468B89C@aol.com>
I uploaded a binary of the patch to povray.binaries.programming today,
so you can download it and use it right away.  Be sure to read the text
file so you'll know how to handle the new syntax.
-Mike
Date: 18 Aug 2000 10:30:38
Message: <399D48CA.3A77256B@insectes.net>
Thank you Mike, wow you eliminated TWO middlemen :-)
<downloading>
Subject: Re: changing topic to cloth :)
Date: 19 Aug 2000 02:55:59
Message: <399E2FB9.4B46BE5E@insectes.net>
Also, I was wondering about your cloth system. *gasp* it's perfect! When I
did my tests a while back, with a little C program which would spit out a
triangle mesh, the numbers always ran off to infinity, and I got NaN mumble
grumble. I translated to POV script, it didn't have that tendancy, but it
took forever to parse.
I think my implementation was too naive. Are you using
deformation-constraints?
Date: 19 Aug 2000 04:38:53
Message: <399E4798.83E18F6C@aol.com>
It's not my cloth system, it's Hash Inc's.  I use their software,
animation master, for most of my modeling and wrote plugins to handle
export to .pov format.  Their homepage is www.hash.com
-Mike
Date: 22 Aug 2000 21:53:20
Message: <39a32e90@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote...
> On Wed, 16 Aug 2000 08:20:45 -0400, Paul Daniel Jones <pdj### [at] psuedu>
> wrote:
> >How can i take a light source and reflect the light off a mirror type
> >object and get both beams of light (incident and reflected) to show up
> >in media? I tried using photons and media.... but I cannot seem to get
> >the reflected light to interact with the media....
> Wasn't there something about a bug with cylinder lights and
> photons/media? (in MegaPOV, that is)?
Photons from cylinder lights behave if they were came from a spotlight (i.e.
the photon beams are not parallell, but spread out).
-Nathan
