POV-Ray : Newsgroups : povray.advanced-users : HF Erosion Server Time
14 Mar 2026 08:55:48 EDT (-0400)
  HF Erosion (Message 21 to 30 of 30)
Subject: Re: HF Erosion
Date: 25 Jul 2000 13:55:21
Message: <397DD493.909A1DC0@schunter.etc.tu-bs.de>
Chris Huff wrote:
> *Lots* of ram...since a 3df file is simply 256-bit grayscale, you would
> need separate 3df files to specify those other variables. And to get a
> large landscape, you would need a fairly high-res landscape file(the
> others, like erodability maps, could be much lower resolution).
> A 256*64*256 file would equal 4MB...3df doesn't have any compression.
> And 512*128*512 would be 32MB. Good thing interpolation is available. :-)
All that is not really effective, because you have to carry the whole "air"
around that is never used.
Date: 25 Jul 2000 13:56:16
Message: <chrishuff-88BBFA.12565725072000@news.povray.org>
In article <8F7CC6C2Fseed7@204.213.191.228>, ing### [at] homenl (ingo)
wrote:
> Could you "abuse" animated png's (mng) for that?
You could...but the file size would probably be bigger than it needs to
be, unless mng supports 256-shade grayscale. And how does it handle the
compression? Are frames compressed individually and stacked together, or
does the compression use info from previous and following frames?
> Also you can stuff more than one image in a single tga (rl encoded) or
> tiff file.
I know about these "stacks", but I don't think the compression is as
efficient as it could be.
It might be better to have a custom format which can handle no
compression, lossless compression, lossy compression(like MPEG), 8-bit
grayscale and 24-bit color. Maybe we could call it 3df. :-)
Or maybe you could just support several animation formats, including MNG
and MPEG.
Date: 25 Jul 2000 13:57:47
Message: <chrishuff-F415F4.12582825072000@news.povray.org>
In article <chrishuff-12226F.11302925072000@news.povray.org>, Chris
Huff <chr### [at] maccom> wrote:
> since a 3df file is simply 256-bit grayscale...
I meant 256-shade grayscale, of course. As in 8-bit grayscale. :-)
Date: 25 Jul 2000 14:29:13
Message: <chrishuff-DA9E86.13295525072000@news.povray.org>
In article <397DD493.909A1DC0@schunter.etc.tu-bs.de>,
> "air" around that is never used.
I'm not sure what you mean...even though it isn't used, you still have
to store it. The "air" is simply any voxel with a density of 0, you have
to store these voxels along with all the others.
An alternative would be to store the coordinates, size, and density of
each voxel. For some files, this would be smaller...but for others, it
would be a lot larger.
A compromise might be to partition the file into cubical chunks, each
one with it's own resolution. That way, large areas of a single value
could be represented as a single voxel, while areas with a lot of
small-scale changes could still be accurately represented. There are
probably better ways to compress the data, though...
Date: 25 Jul 2000 14:39:44
Message: <397DDEF9.7680CA04@schunter.etc.tu-bs.de>
That's what i meant.
I thought of storing the data in form of "columns" of variable height, but
that's probably very slow and not that easy to handle.  Could save a lot of
memory when working with high vertical resolution.
Sounds much like wavelet-compression, that should also work with 3 dimensions,
but it's probably quite calculation intensive.
Date: 25 Jul 2000 14:56:58
Message: <8F7CD1CB8seed7@204.213.191.228>
Sorry, only a link to answer your questions http://www.libpng.org/pub/mng/
I made a 256 colour mng, it was smaller than the animated gif.
Ingo
Date: 25 Jul 2000 15:18:23
Message: <chrishuff-522C54.14190425072000@news.povray.org>
In article <397DDEF9.7680CA04@schunter.etc.tu-bs.de>,
> height, but that's probably very slow and not that easy to handle.
> Could save a lot of memory when working with high vertical
> resolution.
Though not the most efficient method, and mainly useful for
height-field-like voxel structures, that should be quite possible...
> dimensions, but it's probably quite calculation intensive.
I don't think this is anything like wavelet compression, which I think
is based on fourier transforms. I think this would have more in common
with run-length encoding. Basically, divide the voxel data up into
cubes. If the voxels in a cube vary by less than a certain amount, the
resolution within that cube is reduced or the voxels are replaced with a
single, larger voxel. If more than that amount, all of the data is
retained, or maybe the cube gets subdivided.
This would definitely be more computationally expensive than
uncompressed files or your "column" encoding, but could be quite
efficient for many structures.
Date: 26 Jul 2000 10:47:32
Message: <397EF8DB.340374FD@my-dejanews.com>
My (perhaps self-limiting) philosophy is:  why use a paint program when you
can use a vector one, why use a vector program when you can do 3d, why use
a heightfield when you can use an isosurface.  The work need not be
re-created from scratch if another point of view or higher resolution is
required.
Chris Huff wrote:
> In article <397DA95A.B58E927B@my-dejanews.com>,
> gre### [at] my-dejanewscom wrote:
> > Ugh, that would require me understanding what the heck a 3df is.
> Yes...I suppose it would.
> A 3df is a 3D Density File, sort of a 3D bitmap.(which I guess would
> make POV a 3D vector format) Instead of storing polygons or other
> shapes, it stores voxels, the 3D equivalent of a pixel.
> POV has the ability to read these files as a pattern, so you can use
> them as input for an isosurface. It also has interpolation features
> which make lower-resolution 3df files useable.
Date: 26 Jul 2000 14:17:32
Message: <chrishuff-3A37BE.13181426072000@news.povray.org>
In article <397EF8DB.340374FD@my-dejanews.com>,
> when you can use a vector one, why use a vector program when you can
> do 3d, why use a heightfield when you can use an isosurface.  The
> work need not be re-created from scratch if another point of view or
> higher resolution is required.
Mostly I agree, and df3's are even less useful with the blob pattern
available(though sometimes considerably more compact). However, they do
have certain uses, such as the ability to edit specific voxels,
possibilities for external modellers, being a useful format for certain
kinds of data that can't easily be converted to a "vector" format(like
certain volumetric data, MRI scans, etc), the ability to apply filters
to the data, etc.
Date: 31 Jul 2000 10:32:35
Message: <39858CD7.C318C63D@my-dejanews.com>
And I guess NASA is too lazy to post the isosurface equations for
Mars.............
> to the data, etc.
