POV-Ray : Newsgroups : povray.advanced-users : re HF heights Server Time
18 May 2026 10:38:24 EDT (-0400)
  re HF heights (Message 11 to 15 of 15)
Subject: Re: re HF heights
Date: 2 Jul 2000 14:14:39
Message: <395F875B.D2218AA9@aol.com>
I thought there was a function called hf_at that lets you make the highest
part of the HF what you want. eg: hf_at 10 I'm not quite sure.
Mick Hazelgrove wrote:
> Is there a way of finding the highest parts of a hf.  I don't just want
> everything above a certain height but the top of every bump. Hope this is
> clear.
> Hope someone can help.
> Mick
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Date: 2 Jul 2000 14:42:04
Message: <395f8cfc@news.povray.org>
"SamuelT" <STB### [at] aolcom> wrote in message news:395F875B.D2218AA9@aol.com...
Nope, that's a poor man's 'trace()'.  'hf_height_at' returns just the y coord
of the hf cubical (only the starting, untransformed hf) from 0*x, 0*z to x, z.
Date: 2 Jul 2000 22:04:35
Message: <395FE6BC.A5196A39@peak.edu.ee>
Christoph Hormann wrote:
> HF-Lab contains a function for something quite similar, namely filling up local
> minima, source code (in C) can be found at:
I am aware of the function ("fillbasin" or something?), but IIRC it requires
several passes and takes a while to compute even in HF-Lab. Probably not
practical in POV script.
However, you could let HF-Lab itself to do the hard work for you: have the fill
function go over your HF a few times, then use the resultant HF (having fewer
local maxima) with the method I suggested.
In fact, even this might be unnecessary: I think HF-lab can find the first and
second derivatives of HF data, so it should be possible to create a filter
script to find and "mark" the local maxima. Perhaps I'll look into it in a day
or two - or perhaps it is best left to someone who actually knows something
about maths ;)
Margus Ramst
Date: 2 Jul 2000 22:10:14
Message: <395FE80D.688ACCBF@peak.edu.ee>
Hf_height_at should be sufficient in this case, although I must say I have never
used it myself.
Margus Ramst
Date: 3 Jul 2000 01:31:24
Message: <3960252D.37D2F821@schunter.etc.tu-bs.de>
> about maths ;)
I am right now working on a program that generates such masks in a flexible
manner (see http://www.schunter.etc.tu-bs.de/~chris/atg_02.jpg for a first
screenshot).  I am busy with other things and it is a quite large program, so it
won't get finished in the next days, but don't give up hope :-)
