POV-Ray : Newsgroups : povray.advanced-users : Sun/sky energy ratio? Server Time
2 Nov 2024 05:18:54 EDT (-0400)
  Sun/sky energy ratio? (Message 1 to 7 of 7)
Subject: Sun/sky energy ratio?
Date: 22 Jun 2000 10:44:18
Message: <395226CE.4319273A@kivisalo.net>
I would like to do some radiosity testing with outdoors scenes and
for this I need to know how much energy comes just from the sun
to the surface and how much from the rest of the sky. All I need is
the ratio maybe for a clear sky and 50% cloudy.
I tried following Ken's links and altavista but didn't find hard data.
_______________________________________________________________________
Kari Kivisalo                                          www.kivisalo.net
Subject: Re: Sun/sky energy ratio?
Date: 22 Jun 2000 20:23:16
Message: <3952AFB8.A036A74F@mailbag.com>
That depends on how high in the sky the sun is.  At sunrise or sunset,
the sun is scattered through a maximum thickness of atmosphere, and half
of the lit sky is blocked.  At local noon, the sun is brightest, but a
larger proportion of the sky is scattering light as well.  Also,
remember that the sky is typically brighter closer to the sun, even at
noon.  It's not realistic for the sky to have uniform brightness unless
it's either uniformally dark or overcast.
Sorry if this makes life more complicated without answering your
question.
-Mark Gordon
Date: 27 Jun 2000 06:02:36
Message: <39587BE1.162461B9@kivisalo.net>
I was planning to make an image map for the sky and calculate
it's average brightness. If the ratio is 5 I would use color*5
for sun and ambient 1/average_brightness for sky.
All I need is a rough figure for the ratio.
Is it 1,2,5,10 or 20?
K.K.
Date: 27 Jun 2000 09:20:40
Message: <3958aa28@news.povray.org>
"Kari Kivisalo" <kar### [at] kivisalonet> wrote in message
news:39587BE1.162461B9@kivisalo.net...
I'm not sure of the actual idea but if you could go by magnitudes then it
might be plausible.  The Sun is around -25 mag. while the clear blue sky (not
near the sun anyway, but daylight sky) should be around -2 mag.  I'm guessing
this right now from what the planet Venus mag. can be while still seeing it in
the daytime, meaning the sky would be about the same or a little less.
So, looking up astronomical magnitudes might yield some useful info.
Hmm, I just looked up what magnitude the Sun has and I was close, -26.7.
Since Venus varies in brightness it averages probably about -3 (I must've been
thinking of Jupiter before :-) Sure I was...) but I think it's daytime showing
is only when at around -4 or greater mag., which I looked up as well (the
magnitude, not the specifics).  So daylight sky must average about that, -4.
Now, in case you don't know this already, a magnitude of +1 is 2.5 times
dimmer than magnitude 0 and each preceding or proceeding magnitude is likewise
2.5X the adjacent one.
Maybe that will help you, but if I were you I'd look it up someplace.
Date: 18 Aug 2000 16:10:10
Message: <399D983B.26C0137F@kivisalo.net>
I found that the ratio is from 8 to 9. Thanks to aquatic plant
hobbyists :)
Kari Kivisalo                                  http://www.kivisalo.net
Date: 18 Aug 2000 16:43:54
Message: <399da00a@news.povray.org>
news:399D983B.26C0137F@kivisalo.net...
| I found that the ratio is from 8 to 9. Thanks to aquatic plant hobbyists
Oh, that's good, because I multiplied out the number due to magnitude
differences (which I was suggesting before) and it was around 3 and a half
billion times.  By comparison I think your "8 or 9" can be done and get some
renderable results.  ha ha
Date: 18 Aug 2000 17:23:48
Message: <399DA97E.33FA4F62@kivisalo.net>
Direct sunlight produces illumination level of 8000-9000 foot candelas
and clear sky obscured 50% by a tall building produces 500 foot candelas.
