POV-Ray : Newsgroups : povray.advanced-users : Let the rivers flow Server Time
21 Dec 2025 14:02:15 EST (-0500)
  Let the rivers flow (Message 1 to 10 of 10)
Subject: Let the rivers flow
Date: 10 Jun 2000 10:00:02
Message: <394249e2@news.povray.org>
Hi all, as part of a project I'm working on, I'm trying to create a macro in
either Pov or MegaPov that will create a river of sorts, a line of objects
on a hf.
  You'd just enter in the x,y,z of where it should start, and the macro
would then place an object there, then determine the next lowest point,
right next to the previous objects location, and place another object, until
it has either reached a predetermined length , reached the edge of the
object, or has reached a pool, or bottom where there is no more lower
points.
   Hope that makes sense.
Thanks ,
    Kane
Subject: Re: Let the rivers flow
Date: 10 Jun 2000 14:56:28
Message: <39429000.6BAFC574@aol.com>
You might look into the trace function and maybe eval_pigment in MegaPOV. The
trace function will give you a xyz vector of any point on a heightfield,
eval_pigment will return the color of any point in space, as long as you give it
a pigment to test for. Hope that helps.
> on a hf.
> points.
> Thanks ,
>     Kane
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Date: 10 Jun 2000 16:40:37
Message: <3942A7C5.1E1D2ABB@gmx.de>
For heightfields, you could use the "hf_height_at"-function, for
flowline calculation, you could check the erosion function in HF-Lab:
http://www.best.com/~beale/
Your idea is definitely worth trying even though I'm not sure if it
leads to useful results with common patterns.
Date: 11 Jun 2000 01:39:52
Message: <39432628@news.povray.org>
"kane" <ann### [at] mindspringcom> wrote in message
news:394249e2@news.povray.org...
| on a hf.
| points.
Makes sense to me.
I have a crude example of such a thing (non-macro as of yet) only capable of
distributing some blob components along the lowest path just using the
hf_height_at in MegaPov.  If you are saying you are actually making something
yourself then I wish you much luck with it.
Date: 11 Jun 2000 22:22:26
Message: <39444A07.B43591EE@aol.com>
Man, I wish there were erosion functions like that in POV..... I wonder
how to simulate it.....
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Samuel Benge
Date: 15 Jun 2000 10:26:43
Message: <chrishuff-FA0D9E.09305715062000@news.povray.org>
In article <394249e2@news.povray.org>, "kane"
> macro in either Pov or MegaPov that will create a river of sorts, a
> line of objects on a hf.
> point, right next to the previous objects location, and place another
> object, until it has either reached a predetermined length , reached
> the edge of the object, or has reached a pool, or bottom where there
> is no more lower points.
I have done something similar to this...I made a particle with mass and
affected by gravity and used multiple calls to trace() to make the
height field repel it. The particles kind of hover and bounce around the
height field until they find a low area with no slope or go over the
edge. To make the height field repel the particles, I simply used a
bunch of trace() calls pointed from the particles current position in
random directions.
I might still have the source code somewhere...I could look for it and
post it if you are interested.
Personal Web page: http://chrishuff.dhs.org/
Date: 16 Jun 2000 00:50:13
Message: <3949b205@news.povray.org>
Chris Huff wrote in message ...
>random directions.
Now, with the proximity pattern, this can be done automatically with the
eval_pattern() function.  Should make writing such things much easier.
Mark
Date: 16 Jun 2000 20:22:21
Message: <394ac4bd@news.povray.org>
> random directions.
I would definetely be interested...thanks
Date: 20 Jun 2000 17:54:29
Message: <chrishuff-42F2AF.16585120062000@news.povray.org>
In article <3949b205@news.povray.org>, "Mark Wagner"
Something similar could be done(in fact, this is what gave me the idea
for the proximity pattern), but my algorithm may have done more than
just proximity tests(I don't really remember though...).
Still, the proximity pattern could be used to make something close to it
with much faster parsing.
I will dig up the source and post it when I have a chance(an incoming
severe thunderstorm may slow me down).
Date: 22 Jun 2000 10:55:58
Message: <chrishuff-68FCEF.10002222062000@news.povray.org>
In article <chrishuff-42F2AF.16585120062000@news.povray.org>, Chris
I apparently deleted the file while spring cleaning...fortunately, the
scene was pretty easy to duplicate. Posted in povray.text.scene-files as
"Flow.pov".
I might expand on this, adding water flow/spray effects, friction, etc,
but this demonstrates the basic technique. I used trace() because not
only the proximity but the direction is needed...eval_pattern() could
still be used, but you would have to use several calls of the function
to determine the general direction.
