POV-Ray : Newsgroups : povray.advanced-users : vlength( ) Server Time
3 Aug 2026 02:59:56 EDT (-0400)
  vlength( ) (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: vlength( )
Date: 10 Jun 2000 15:42:40
Message: <39429a30@news.povray.org>
What are you trying to do?
  The average of the components of a vector doesn't sound like anything
rational. The length of a vector sound much more useful.
Date: 12 Jun 2000 18:37:00
Message: <394566DD.DAC31764@aol.com>
It's for the eval_pigment stuff I've been using. I needed to convert a color
vector into a float value so I could use it for elevation. The best way I
could think of doing this would be averaging the components of the color
vector. I'm now using a macro instead of vlength, and it works great.
Date: 12 Jun 2000 19:31:22
Message: <slrn8katie.7pu.ron.parker@linux.parkerr.fwi.com>
Use the NTSC conversion for rgb to luminance.  You should see some examples
of it in the POV source.  Two of them might even match. :)
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 12 Jun 2000 23:01:49
Message: <3945A4C5.517F61D8@aol.com>
What pov source? The actual code which makes POV-Ray?
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Date: 13 Jun 2000 09:08:12
Message: <3946323c@news.povray.org>
SamuelT <STB### [at] aolcom> wrote:
: It's for the eval_pigment stuff I've been using. I needed to convert a color
: vector into a float value so I could use it for elevation.
  So in practice what you are trying to do is to convert a color to b/w
(ie. a brightness value).
  There's an exact formula on how each color component affects the brightness,
and I don't remember exactly the values, but this might be a good
approximation:
brightness = red*0.25 + green*0.6 + blue*0.15
Date: 13 Jun 2000 09:27:48
Message: <slrn8kcej1.8e5.ron.parker@linux.parkerr.fwi.com>
Yes.  For example, in png_pov.c you'll see:
color = (png_byte)floor((line_data[col][RED]*0.30 +
                         line_data[col][GREEN]*0.59 +
                         line_data[col][BLUE]*0.11) * 255.0);
Date: 13 Jun 2000 12:36:08
Message: <394663CA.15F8EBC7@aol.com>
Ron posted this from the POV source at 6:30:
Perhaps I can use your idea+his values to make it work?
> approximation:
Date: 13 Jun 2000 13:14:09
Message: <39466CB5.8A7BD9A9@aol.com>
Well, this simple macro seems to be working. It is a combination of your idea and
Ron's pasted code.
#macro Lum( Color )
 Color.x*.3
 +Color.y*.59
 +Color.z*.11
Funny thing, Photoshop's desaturation seems to be goofy. It gives unexpected
results, although the desaturation tool itself seems to be fine.
> approximation:
Date: 14 Jun 2000 04:28:49
Message: <39474241@news.povray.org>
: color = (png_byte)floor((line_data[col][RED]*0.30 +
:                          line_data[col][GREEN]*0.59 +
:                          line_data[col][BLUE]*0.11) * 255.0);
: Perhaps I can use your idea+his values to make it work?
  It's not my idea. It's a commonly known equation.
  Using those values it would be:
brightness = red*0.3 + green*0.59 + blue*0.11
Date: 16 Jun 2000 16:21:35
Message: <394A8C26.9378A1C8@online.no>
I see that Ron Parker and Warp already have suggested some conversion
formulas for your problem.
Here are links to some more info about such formulas:
http://www.neuro.sfc.keio.ac.jp/~aly/polygon/info/color-space-faq.html
(Look at the end of item 5.2 - HSL, HSV)
(Rewritten html version of above page ?)
http://members.xoom.fr/scorpion/docs/txt/color_faq.html
(9.2 - Color look-up table to a gray scales)
http://www.inforamp.net/~poynton/notes/colour_and_gamma/ColorFAQ.html#RTFToC9
Tor Olav
mailto:tor### [at] hotmailcom
