POV-Ray : Newsgroups : povray.advanced-users : Air disruption question Server Time
16 May 2026 19:40:54 EDT (-0400)
  Air disruption question (Message 16 to 25 of 25)
Subject: Re: Air disruption question
Date: 28 May 2000 15:06:08
Message: <39316e20@news.povray.org>
Wasn't there a way in POV 3.0 to specify some more IOR-values for a surface
by using layered textures, because of IOR was in the finish-statement ...
In think I had read in the helpdocs that people were using it for "obscure
things" ...
Ok ... I don't think this will solve the problem in a correct way, but I
think it would have been an alternative ...
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Date: 28 May 2000 20:55:12
Message: <3931B21E.73ED6507@peak.edu.ee>
There was, but the result was not physically correct. The IOR only changed at
the surface, it stayed constant as the ray passed through the object's volume.
Margus Ramst
Date: 29 May 2000 00:55:14
Message: <3931f832$1@news.povray.org>
Simen Kvaal wrote in message <3930f206$1@news.povray.org>...
>This brings to mind a good suggestion for a feature: Variable ior in media;
>kind of like a ior_map.
See the discussions in povray.binaries.images, povray.general,
povray.programming, povray.unofficial.patches, and possibly even
povray.windows and povray.off-topic.
This has been discussed repeatedly, and the overall opinion is "Yes, it can
be done, but you really need a Cray to do it."
Mark
Date: 29 May 2000 15:11:25
Message: <3932c0dd@news.povray.org>
So why not include it to POV ??? If the user thinks his computer is
cray-equal than he will use it... If he has no cray he should know whom's
fault it is ...
Of course, for developers it will be hard, to confirm the correctness of
this feature but why not ???
Date: 29 May 2000 15:45:11
Message: <chrishuff-2E1FA2.14490129052000@news.povray.org>
In article <3932c0dd@news.povray.org>, "Jan Walzer"
> fault it is ...
It is not only processor intensive, it also would be difficult to code.
A large amount of code would need to be rewritten, and it could be hard
to get things right for overlapping objects.
Personal Web page: http://chrishuff.dhs.org/
Date: 31 May 2000 12:51:07
Message: <393542fb$1@news.povray.org>
whom's
> > fault it is ...
I thought the media-code could be used for that, just instead of calculating
the color of the "current particle" change the direction-vector of the
traced ray ???
Quite the idea of adding a new type in the media-part, equal to emission,
absorption and scattering there could be something called
optical_density....
But I think the samplecount in media has to be increased dramatically...
Now, You are the coders ... that was just, what came into my mind ...
Date: 31 May 2000 17:07:37
Message: <39357143.E4A3D7E7@peak.edu.ee>
> traced ray ???
Well, I am no coder. But if I understand correctly how media works, the problem
is as follows:
To calculate the color of media along a particular ray, first the points are
found where the ray enters and exits the object. Between these points the ray is
divided into a specified number of intervals, and a (variable) number of samples
is taken within each interval.
This method relies upon the ray traversing the volume in a straight line, from
enter to exit. You can probably see why this wouldn't work if the ray were to
curve in an (unpredictable) manner.
Margus Ramst
Date: 31 May 2000 20:05:43
Message: <3935a8d7@news.povray.org>
"Margus Ramst" <mar### [at] peakeduee> wrote in message
news:39357143.E4A3D7E7@peak.edu.ee...
| > traced ray ???
| is as follows:
I was thinking the refractions were most probably done simply by angling the rays
according to surface geometry, so basically no curvatures of the rays themselves only
straight lines, albeit turned from original directions.  Where curvature comes in,
seems
to me, would be the implementation of this whole idea about variable ior where these
lines of rays would be continously rerouted through the interiors of objects.
Date: 1 Jun 2000 04:48:47
Message: <3936236f@news.povray.org>
calculating
> > traced ray ???
problem
> is as follows:
are
ray is
samples
from
to
Yes ... I think this is the way it's working, but
<experiment>
Lets have N intervals
If we say the ray is in the 1st interval on his way. Then we find a new
opt_density value in the media. Now lets bend the ray to the new direction.
By using the new directionvector we could determine two other points, where
(our new) ray intersects. The line between these both could be split again
in N intervals and we only look on the 2nd Point there on. Now we find a new
value and so on ...
Yes, I think this could be way it could be working, but the result will
hardly depend on N. For low N and a very small scaled or high turbulenced
Media it may create rather very obscure things... Sure, the best way would
be, to integrate about the ray, but I think the idea is there, (maybe in
POV4 *g*)
</experiment>
I'll try to find the old discussion about this in my newsreader and think
about it ...
Currently I've not a real Idea of Coding in C so I can't try it on myself,
but maybe someday ...
Date: 2 Jun 2000 17:24:51
Message: <3938184E.BADCB3F4@peak.edu.ee>
Jan Walzer wrote:
> <experiment>
[snip]
> </experiment>
Yes, something like this has been suggested and it might work.
My point was that it would require a rewrite of the volume sampling method.
Probably a large one. If you (or anyone else) is willing to try implementing it,
I wish you nothing but the best of luck.
But personally, I think it's not worth the trouble, at least until the average
computer gets considerably faster. Currently, even scattering media has to be
used sparingly. Variable IOR _will_ be worse.
Margus Ramst
