POV-Ray : Newsgroups : povray.advanced-users : Intersection test for triangles Server Time
14 Oct 2025 14:33:29 EDT (-0400)
  Intersection test for triangles (Message 1 to 10 of 15)
Subject: Intersection test for triangles
Date: 23 May 2000 20:26:59
Message: <392B20F3.726230DD@faricy.net>
Given the points of two triangles, how do I test for intersection?
Thanx
Subject: Re: Intersection test for triangles
Date: 24 May 2000 07:46:18
Message: <392BC0F8.5BA8C2EF@erols.com>
Try this:
Find the planes that contain each triangle; if they are parallel (but
not coincident), the triangles do not intersect.
Find the line along which the planes intersect.
Find the part of the line that lies within the first triangle.  If the
line lies out of the triangle, the triangles do not intersect.
Find the part of the line that lies within the second triangle.  If the
line falls out of the triangle, the triangles do not intersect.
If the two resulting line segments overlap, the triangles intersect.
Otherwise, they don't.
Hope this helps,
John
Date: 24 May 2000 08:03:25
Message: <392bc50d@news.povray.org>
John VanSickle <van### [at] erolscom> wrote:
: Find the line along which the planes intersect.
  What is the equation for the intersection line of two planes?
Date: 24 May 2000 09:18:45
Message: <392BC8D9.154B1E64@peak.edu.ee>
Well, I'm making this up on the go, but:
The function for a plane is
x * Normal.x + y * Normal.y + z * Normal.z - Distance = 0
And along the intersection line, the functions of the two planes would be equal,
so the function should be:
F(Plane1) - F(Plane2) = 0
Margus Ramst
Date: 24 May 2000 10:21:44
Message: <392be578@news.povray.org>
"David Fontaine" <dav### [at] faricynet> wrote in
news:392B20F3.726230DD@faricy.net...
Try this page:
http://apodeline.free.fr/FAQ/CGAFAQ/CGAFAQ-6.html#ss6.22
Sebastian Strand
  E-mail: thezeb -at- bigfoot -dot- com
  URL: http://www.zeb.f2s.com/
Date: 24 May 2000 18:26:19
Message: <392C5626.C0BC36B0@faricy.net>
John VanSickle wrote:
> Try this:
> Hope this helps,
> John
Wow, sounds like it will take a long time to parse. (I actually want it to
test cubes for intersection, but the faces can be considered two triangles,
and if the faces don't intersect the cubes don't. For the bowl-full-o-cubes
thing...)
Date: 24 May 2000 18:32:38
Message: <slrn8iomr3.47a.ron.parker@linux.parkerr.fwi.com>
>thing...)
Not necessarily true, unless all the cubes are the same size.
If you're intersecting cubes, and they're all the same size, and they're
axis-aligned, it suffices to check whether any corner of either cube is
inside the other cube.  If they're not axis-aligned but still the same
size, you can check whether any edge of one cube intersects a face of the
other cube.  (Likewise, to see if two triangles intersect, it suffices to
check whether any edge of one triangle intersects the face of the other
triangle.)
If you're using MegaPOV, you can use trace to determine whether they
intersect.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
These are my opinions.  I do NOT speak for the POV-Team.
Date: 24 May 2000 21:26:59
Message: <392C807F.D4BB4D78@faricy.net>
? How can two cubes intersect if their faces never do?
> triangle.)
<Data> I assure you the set is sufficiently randomized. </Data>
> intersect.
*opening docs*
Date: 24 May 2000 21:54:46
Message: <392C8B5F.23367DED@erols.com>
Not an equation, but a specification.  This requires a point
(any point that lies along the desired line will do), and a vector.
I would get the vector by taking the cross-product of the normal
vectors of the two original planes.
To find the point, I would find the plane to which this vector
is normal and which contains the origin.  The place where all
three planes intersect is as good a point to use as any (it
happens to be the point on the line that is closest to the
origin).
John
ICQ: 46085459
Date: 24 May 2000 21:57:22
Message: <392C8BFD.F25444F8@erols.com>
If they are the same size, they can't.  If they are different sizes,
then one could be contained entirely within another.
John
ICQ: 46085459
