POV-Ray : Newsgroups : povray.advanced-users : Convert matrix to rotate ? Server Time
15 Jul 2026 20:57:21 EDT (-0400)
  Convert matrix to rotate ? (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Convert matrix to rotate ?
Date: 20 May 2000 19:18:18
Message: <39271d3a@news.povray.org>
"Tor Olav Kristensen" wrote:
> I think there must be an error in your second macro.
> The variable X (in the 3rd line) is not defined.
> Is this meant to be a lower case x ?
No, it's supposed to be VectorX. Thank you for pointing it out.
This should be correct:
#macro Vectors2Rotate (VectorX,VectorY) // by Rune S. Johansen
   #local RotZ = FindAngle(x,<VectorX.x,VectorX.y,0>,z);
   #local RotY = FindAngle(x,vrotate(VectorX,-RotZ*z),y);
   #local RotX = FindAngle(vrotate(y,<0,RotY,RotZ>),VectorY,VectorX);
   <RotX,RotY,RotZ>
> And I believe your first macro could be simplified to this:
<snipped code>
Hmm, you're probably right. I just write code using my own math skills,
which means that it is not always so optimized... I will have a look your
version.
Greetings,
Rune
Updated April 25: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Date: 22 May 2000 11:09:07
Message: <slrn8iik23.17k.ron.parker@linux.parkerr.fwi.com>
On Sat, 20 May 2000 15:46:55 +0200, Rune wrote:
>"Ken" wrote:
>> Rune wrote:
>> > So is there any way?
>> If it is possible these two sites will tell you -
>> http://www.gate.net/~shipbrk/raytrace/matrix.html
>> http://www.erols.com/vansickl/matrix.htm
>No of those pages explain how to do what I want to do, although the second
>one comes close. But thanks for the links anyway! :-)
I once did the math to figure out how to turn a matrix into a rotation,
a scale, and a transform (provided it didn't have a significant skew
component.)  If you still need it (not that it looks like you do) I can
email it to you or post it here.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
These are my opinions.  I do NOT speak for the POV-Team.
Date: 22 May 2000 14:43:34
Message: <39297fd6@news.povray.org>
> matrix into a rotation, a scale, and a transform
> looks like you do) I can email it to you or post
> it here.
My own problem is solved now, but it would be very interesting to see your
solution anyway! Mine did the rotation part only.
> component.)
You can do that with rotate, scale and translate too. Actually I would guess
that any transformation can be done using those. Not that I need it... :-)
Greetings,
Rune
Date: 22 May 2000 17:46:34
Message: <tfajisof9ihiip7do7f9mjud8uugc4i853@4ax.com>
On Mon, 22 May 2000 17:46:55 +0200, "Rune" <run### [at] inamecom>
>> component.)
If you mean you can skew an object by rotation, translation and
scaling, I think you've been mislead. Mr. VanSickle is The One when it
comes to manipulating the matrix keyword and I trust whatever he says
on the subject, but this time I doubt he'd disagree. Then again, if I
am wrong, I will learn something new :)
Peter Popov ICQ : 15002700
Date: 22 May 2000 18:03:34
Message: <3929B3C4.C15692F@merlin.net.au>
box{
  0,1
  rotate z*45
  scale <1,2,1>
  rotate z*-45}
PoD.
Date: 22 May 2000 18:45:42
Message: <qtdjisoodpngvfjuqpno5hdq9c6mbonj70@4ax.com>
On Tue, 23 May 2000 07:55:08 +0930, PoD <pod### [at] merlinnetau> wrote:
>box{
>  0,1
>  rotate z*45
>  scale <1,2,1>
>  rotate z*-45}
This is not what I had in mind. This only scales the local coordinate
axes but does not change the angle between them, as skewing does (I
think). Something like matrix <1,1,0,0,1,0,0,0,1,0,0,0> is more along
the lines of what I have in mind.
Date: 22 May 2000 19:57:34
Message: <3929BB96.1249FB24@peak.edu.ee>
This transform does indeed skew the object, but you'd have to use a bit of trig
to get the skewing along a specific axis.
Margus Ramst
Date: 22 May 2000 20:13:35
Message: <24jjisc9avdl16s2ggj9cmnu6ir9750ik1@4ax.com>
On Tue, 23 May 2000 01:58:30 +0300, Margus Ramst <mar### [at] peakeduee>
I see, so shearing comes down to scaling along (an) axe(i)s which are
(is) not perpendicular to the local axes. Am I right in guessing that?
If so, thanks for clearing it up for me! If not, I'd be thankful if
you cleared it up for me <grin>
Date: 22 May 2000 20:50:24
Message: <3929C7F9.972F7B26@peak.edu.ee>
Well, yes. That's one way of looking at it. Of course, matrix shearing
approaches the problem from a different perspective - the scaling of a point
along one global axis is (linearly) bound to the distance of this point along
another global axis. E.g. when Point.x increases, the multiplier (scale) of
Point.y increases.
Margus Ramst
Date: 23 May 2000 19:19:57
Message: <392B1591.B312F16F@erols.com>
My matrix page does not explicitly spell this out, but shearing can
be done with the proper combination of rotate, non-uniform scale, and
another rotation.  It is far easier to use a matrix.  I would have
whipped up some macros for shearing, but the many different ways that
shearing can be specified makes it troublesome to decide how the syntax
should work.
John
ICQ: 46085459
