POV-Ray : Newsgroups : povray.advanced-users : Convert matrix to rotate ? Server Time
11 Jul 2026 19:01:04 EDT (-0400)
  Convert matrix to rotate ? (Message 11 to 16 of 16)
Subject: Re: Convert matrix to rotate ?
Date: 22 May 2000 18:03:34
Message: <3929B3C4.C15692F@merlin.net.au>
Peter Popov wrote:
> If you mean you can skew an object by rotation, translation and
> scaling, I think you've been mislead. Mr. VanSickle is The One when it
> comes to manipulating the matrix keyword and I trust whatever he says
> on the subject, but this time I doubt he'd disagree. Then again, if I
> am wrong, I will learn something new :)
box{
  0,1
  rotate z*45
  scale <1,2,1>
  rotate z*-45}
PoD.
Date: 22 May 2000 18:45:42
Message: <qtdjisoodpngvfjuqpno5hdq9c6mbonj70@4ax.com>
On Tue, 23 May 2000 07:55:08 +0930, PoD <pod### [at] merlinnetau> wrote:
>box{
>  0,1
>  rotate z*45
>  scale <1,2,1>
>  rotate z*-45}
This is not what I had in mind. This only scales the local coordinate
axes but does not change the angle between them, as skewing does (I
think). Something like matrix <1,1,0,0,1,0,0,0,1,0,0,0> is more along
the lines of what I have in mind.
Peter Popov ICQ : 15002700
Date: 22 May 2000 19:57:34
Message: <3929BB96.1249FB24@peak.edu.ee>
This transform does indeed skew the object, but you'd have to use a bit of trig
to get the skewing along a specific axis.
Margus Ramst
Date: 22 May 2000 20:13:35
Message: <24jjisc9avdl16s2ggj9cmnu6ir9750ik1@4ax.com>
On Tue, 23 May 2000 01:58:30 +0300, Margus Ramst <mar### [at] peakeduee>
I see, so shearing comes down to scaling along (an) axe(i)s which are
(is) not perpendicular to the local axes. Am I right in guessing that?
If so, thanks for clearing it up for me! If not, I'd be thankful if
you cleared it up for me <grin>
Date: 22 May 2000 20:50:24
Message: <3929C7F9.972F7B26@peak.edu.ee>
Well, yes. That's one way of looking at it. Of course, matrix shearing
approaches the problem from a different perspective - the scaling of a point
along one global axis is (linearly) bound to the distance of this point along
another global axis. E.g. when Point.x increases, the multiplier (scale) of
Point.y increases.
Margus Ramst
Date: 23 May 2000 19:19:57
Message: <392B1591.B312F16F@erols.com>
Peter Popov wrote:
> On Mon, 22 May 2000 17:46:55 +0200, "Rune" <run### [at] inamecom>
> wrote:
> >You can do that with rotate, scale and translate too. Actually I would guess
> >that any transformation can be done using those. Not that I need it... :-)
My matrix page does not explicitly spell this out, but shearing can
be done with the proper combination of rotate, non-uniform scale, and
another rotation.  It is far easier to use a matrix.  I would have
whipped up some macros for shearing, but the many different ways that
shearing can be specified makes it troublesome to decide how the syntax
should work.
John
ICQ: 46085459
