POV-Ray : Newsgroups : povray.advanced-users : Realistic Sky? Server Time
16 Mar 2026 15:31:48 EDT (-0400)
  Realistic Sky? (Message 1 to 5 of 5)
Subject: Realistic Sky?
Date: 16 Apr 2000 08:52:17
Message: <38f9b781@news.povray.org>
I'm trying to make a realistic looking sky, so far without too much success.
I'm fairly new to Pov-Ray so i'm probably doing it the wrong way or
something.
So far i've used the built in sky_sphere, but the problem with this is that
the clouds just don't look realistic because there is no perspective.
Someone suggested having a seperate blue background sky sphere and a smaller
cloud sphere with a partially transparent color map and then flattening
both. They also suggested adding fog to the scene to further increase the
realism of the scene.
If anyone has any experience in this area could they please make some
suggestions and post some suitable code? I'm beginning to lose the will to
live!
Thanks
Paul
Subject: Re: Realistic Sky?
Date: 16 Apr 2000 09:05:28
Message: <38F9BA68.8EB6BF12@pacbell.net>
> live!
In the two scene files groups on this news server have been posted
a few clouds scene files. A couple of them are quite realistic using
POV-Ray's medai feature. Just search for clouds in the subject lines
in those groups and you should find a starting point. Also the IRTC
entries often have the source available for study. You might try
browsing some of the out door subjects looking for realistic skies
and see if they included the source with the image. It is a valuable
resource in this regard. http://www.irtc.org
Date: 16 Apr 2000 16:33:54
Message: <38FA22FD.8B94B7D2@fci.net>
Hey dude!  I feel your pain.  Here's a reasonable alternative to media.  Works
best for sunset or evening pics.
//Start
#declare Color = <1,.625,.25>
#declare LightColor = (Color+.5)/2
fog {fog_type 2 distance 150000 rgb LightColor transmit .25
fog_offset 0
fog_alt 2500
fog {
distance 1500 rgb <.9,.85,1>/2 transmit .175
#declare Bright = 24
#declare DesertSky =
sphere {0,1
//Back Drop
finish {ambient 2 diffuse 0}
gradient y
color_map {
[0 rgb 1.5*Bright*Color]
[.5 rgb <.5,.675,1>/2]
scale 1/<2,.5,2>
finish {ambient 1 diffuse 0}
bozo
color_map {
[.5 rgb <.5,.675,1> transmit 1 ]
[1 rgb 1*Bright*Color transmit .45]
translate 1
scale .5
turbulence <2,1,2>
scale 10
warp {turbulence <2,1,2>}
scale 1/10
lambda 2
scale <1,.75,1>
scale .25
bozo
color_map {
translate 1
scale .25
turbulence 1
scale 10
scale 1/10
lambda 4
scale <1,.75,1>
scale .5
//Back Shadow
bozo
color_map {
[.65 rgb <.375,.5,1> transmit 1]
[.85 rgb 2*Bright*Color]
turbulence .25
scale 10
warp {turbulence <2,1,2>/4}
scale 1/10
scale .25
translate -.025*y
translate .05*x
scale .5
//Light Part
bozo
pigment_map {
[.65 rgb <.5,.675,1>/1.5 transmit 1]
[.775 bozo color_map {[0 rgb .875][1 rgb 2*Bright*Color]} turbulence .5 scale
.25]
turbulence .25
scale 10
scale 1/10
scale .25
scale .5
//Dark Part
bozo
color_map {
[.65 rgb <.5,.675,1> transmit 1]
[.975 rgb 0 ]
turbulence .25
scale 10
scale 1/10
scale .25
translate -.06*y
translate .1*x
scale .5
finish {ambient .5 diffuse 0}
//Back Shadow
bozo
color_map {
turbulence .375
scale 10
warp {turbulence <2,1,2>/3}
scale 1/10
scale .125
translate -.025*y
translate .05*x
scale .5
//Light Part
bozo
pigment_map {
[.775 bozo color_map {[0 rgb .875][1 rgb 4*Bright*Color]} turbulence .5 scale
.25]
turbulence .375
scale .125
scale .5
//Dark Part
bozo
color_map {
[.975 rgb <.1,.1,.2> transmit .675/2]
turbulence .375
scale 10
scale 1/10
scale .125
translate -.05*y
translate .08*x
scale .5
gradient y
color_map {
[0 rgb <.5,.675,1>*1.5 transmit .25]
[.25 rgb <.5,.675,1>/1.5 transmit 1]
rgb <.25,.25,1>/4 transmit .25}
scale 2000000
scale <4,.5,4>
hollow on
object {DesertSky rotate 45*y scale -x}
//End
Do hope this helps.
H.E. Day
Date: 16 Apr 2000 17:09:17
Message: <itakfs4tdb9gaffo5so7taelfg3jc2as07@4ax.com>
<snipped lotsa useful code>
Hey man, are you taking the same code indentation course that Ken
does? :)
Peter Popov ICQ : 15002700
Date: 16 Apr 2000 17:11:02
Message: <38FA2C2F.7207CE3D@pacbell.net>
> does? :)
Looks perfectly natural to me ;^ }
