POV-Ray : Newsgroups : povray.advanced-users : Question! Server Time
15 Jan 2025 00:56:02 EST (-0500)
  Question! (Message 1 to 10 of 13)
Subject: Question!
Date: 22 Mar 2000 13:01:18
Message: <38d90a6e$1@news.povray.org>
Given an object (for example an arbitrary isosurface). Is it any way to
calculate, using for example trace, the lower y-coordinate, for example, so
that I can place it as close as possible to the ground?
Simen.
Subject: Re: Question!
Date: 22 Mar 2000 15:32:43
Message: <chrishuff_99-890CEE.15344922032000@news.povray.org>
In article <38d90a6e$1@news.povray.org>, "Simen Kvaal"
> to calculate, using for example trace, the lower y-coordinate, for
> example, so that I can place it as close as possible to the ground?
Usually, this will work:
#declare groundHeight = 0; // distance along y-axis of ground
#declare MyObj =
...object declaration...
object {MyObj
    translate y*(groundHeight-min_extent(MyObj).y)
However, with some objects(like blobs), it is imprecise. The min_extent
function returns the lower left front(-x,-y,-z) corner of the bounding
box of the object, and the bounding box is not always exactly
calculated(it would be too difficult to calculate for some objects). It
should work fine for isosurfaces, though.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Date: 22 Mar 2000 15:44:45
Message: <chrishuff_99-C04F94.15465222032000@news.povray.org>
In article <chrishuff_99-890CEE.15344922032000@news.povray.org>, Chris
Huff <chr### [at] yahoocom> wrote:
> It should work fine for isosurfaces, though.
Oops!
Actually, it sometimes won't. It should work fine, as long as the
isosurface contacts the lower part of the contained_by object.(or is
close enough the gap doesn't matter)
Date: 23 Mar 2000 06:10:16
Message: <38d9fb98@news.povray.org>
Simen Kvaal <sim### [at] studentmatnatuiono> wrote:
: Given an object (for example an arbitrary isosurface). Is it any way to
: calculate, using for example trace, the lower y-coordinate, for example, so
: that I can place it as close as possible to the ground?
  If it's an isosurface defined with a function, then you can calculate
the lowest point using mathematics.
Date: 23 Mar 2000 11:28:23
Message: <38da4627$1@news.povray.org>
This is not true. Many functions have no algebraic solutions. (Above 5th
order polynomials it's impossible!)
The surface in question is:  x^4 + y ^4 + z^4 - (x^2 + y^2 + z^2) -1 = 0.
This is a fouth order plynomial, and is not easily solved using algebra.. A
numerical methos would be better...
Simen.
Date: 23 Mar 2000 18:38:26
Message: <XabaOGJ2TFw0Mrf=rUXtavRUQB6F@4ax.com>
On Wed, 22 Mar 2000 19:01:13 +0100, "Simen Kvaal"
#macro Place_On_Earth ( Object, Steps ) // y is up :)
  #local Min = min_extent ( Object );
  #local Max = max_extent ( Object );
  #local Increment = ( Max - Min ) / Steps;
  #local X = Min.x; #local Continue=1; #local Y = Min.y;
  #while ( (Y < Max.y) & Continue )
     #while ( (X < Max.x) & Continue )
       #local Trace = trace ( Object, <X,Y,Min.z>, z, Normal );
       #if ( vlength (Normal)) #local Continue = 0; #end
       #local X = X + Increment.x;
     #local Y = Y + Increment.y;
  object { Object translate -y * ( Y - Increment.y ) }
It *might* just work a prima vista but I doubt it as I typed it
directly in the newsreader ;) Anyway, you get the idea.
Peter Popov ICQ : 15002700
Date: 24 Mar 2000 03:56:25
Message: <38db2db8@news.povray.org>
If I remember right, you can calculate minimums and maximums by deriving
the function twice. So there wouldn't be any problem.
Date: 24 Mar 2000 06:48:25
Message: <38db5609@news.povray.org>
But we are not talking about finding maxima and minima of real-valued
functions, because the general funciotn-surface is a level surface of a
function of three variables. So, deriving a sphere function, x*x+y*y+z*z-1,
gives you a 3-vector (gradient): grad f = <2x. 2y, 2x>. Solving this for
zero as you would with normal functions yields <0, 0, 0>, which means that
the function has a extreme point at <0, 0, 0> In fact, it's a minimum, but
this is at the centre of the sphere, which is _not_ the lowes point on the
sphere. (Of course not, I'd say.) This minimum represents the 'density' of a
4-d-object, and the sphere itself is the set of all denisties with a
specific value, for example r^2.
It would be lesser problems if one were able to solve the function for for
example y by saying:
x*x+y*y+z*z=1 => y = +-sqrt(1-x*x-z*z) and this function we can derive and
find maxima and minima of. BUT NOT from for example: sin x - x = 0, which
have noe algebraic solutions!
Warp skrev i meldingen <38db2db8@news.povray.org>...
Date: 24 Mar 2000 06:49:28
Message: <38db5648$1@news.povray.org>
Thanks! :D Works with isos too? (Haven't got the time to test it right now!)
Simen.
>#end
Date: 24 Mar 2000 16:41:34
Message: <HuHbOHlNFHWhth7T=F4cbNGobalo@4ax.com>
On Fri, 24 Mar 2000 12:49:27 +0100, "Simen Kvaal"
>Simen.
You mean it ran the first time?!?!
