POV-Ray : Newsgroups : povray.advanced-users : Reading directly into an Array Server Time
24 Feb 2025 07:43:08 EST (-0500)
  Reading directly into an Array (Message 1 to 2 of 2)
Subject: Reading directly into an Array
Date: 19 Mar 2000 17:05:02
Message: <38d54f0e@news.povray.org>
I have an ASCII file that I wish to read into an array.
File is 117 records separated by CR/LF and
each record has 6 text elements separated by a comma.
#fopen SymFile "c:\pf\bin\sym.asc" read
#declare Syms=array [117] [6] { #fread (SymFile, defined)}
Can somebody steer me in the right direction..
David
Subject: Re: Reading directly into an Array
Date: 19 Mar 2000 18:21:48
Message: <38d5610c@news.povray.org>
To use the data with POV-Ray's file I/O the text values will need to be
quoted, and there will need to be commas at the end of every line (i.e. a
newline does not count as a delimiter).  Then you could read in the file so:
   #fopen F, "MyFile.txt", read
   #local MyArray = array[117][6]
   #local M = 0; #while (M < 117)
      #local N = 0; #while (M < 6)
         #read (F, Data)
         #declare MyArray[M][N] = Data
      #local N = N + 1; #end
   #local M = M + 1; #end
   #fclose F
The temporary String variable is required as the #read command cannot save
the file data directly to an array variable.  An alternative is to modify
the data file so it begins with the line:
   array[117][6] {
Then add opening and closing brackets to each line:
   { "data1", "data2", "data3", "data4", "data5", "data6" },
and end with a final closing bracket (and no comma after the last subgroup):
This way you can include the file directly into your scene (e.g. #declare
MyArray = #include "MyArray.inc") which may be quicker to parse than using
the #read command.
