POV-Ray : Newsgroups : povray.advanced-users : File I/O question Server Time
15 Oct 2025 00:55:21 EDT (-0400)
  File I/O question (Message 1 to 4 of 4)
Subject: File I/O question
Date: 10 Mar 2000 13:40:59
Message: <38c941bb@news.povray.org>
I would like to be able to selectively read from a text file with records
terminated with a line feed.
The #read - #write looks just fine for a single item file but how can I
select a specific record?
Subject: Re: File I/O question
Date: 10 Mar 2000 19:32:32
Message: <38C99491.45FB4438@peak.edu.ee>
Random reading is not very easy with POV. You have to move through records one
by one, i.e. to get to record N you have go through 1,2,3,...,N #reads. For
example get 10th record do sth. like this (untested):
#fopen F "file" read
#local N=10; //Needed record
#local C=0;
//Jump through the first 9 records
#while (C<N)
  #read(F,X)
#read(F,NeededValue)
Of course if all jumps are are known to be forward (i.e. the next record is
always somewhere after the current one) you don't have to start from the
beginning every time (to restart from the beginning you have to close the file
and reopen it)
Not very elegant; if memory is not a critical issue, I suggest you read all
values into an array, and use this instead.
Also note that values _have_ to be separated by commas.
Margus
Date: 10 Mar 2000 21:46:01
Message: <38c9b369$1@news.povray.org>
Looks like this would be a useful extension area for the language
If the full file is placed into an array. What is the array item select
procedure. I don't see anything in the Help and not much in the written
Docs.
David
Margus Ramst <mar### [at] peakeduee> wrote in message
news:38C99491.45FB4438@peak.edu.ee...
one
For
> #local N=10; file://Needed record
> #local C=0;
> file://Jump through the first 9 records
> #while (C<N)
>   #read(F,X)
> #end
is
file
> and reopen it)
all
> Margus
records
Date: 11 Mar 2000 09:48:26
Message: <38CA5D24.82015B3E@peak.edu.ee>
I quite agree.
> Docs.
For example, the first item of a (one-dimensional) array MyArray is referred to
as MyArray[0] (records are zero-based). Each initialized array item can be
thought of as a declared variable. So you can perform any operations you would
with declared variables such as:
#declare X = X + MyArray[0];
Also, you have to bear in mind that a particular array can only contain records
of one data type (float, vector, object, etc).
Margus
