Ken wrote:
> I have but without the proper educational background there are times it
> makes absolutely no sense what so ever. An example is sometimes worth
> 1000 documented words. If a person had understood the original explaination
> they would not have asked for clarification. What is easy for you may be
> difficult for others. Not every thing in POV-Ray is inherently obvious
> or intuitive. We are here to help not criticize. Dare to teach so that
> others may learn. Patients is a virtue. Lead by example. Give till it
> hurts.
The virtues of a noble POVer ... I wonder if you have sworn an oath for
it.
Thank you Ken! I really mean it.
Marc
Marc Schimmler
In article <38C729F2.FF588583@faricy.net>, David Fontaine
<dav### [at] faricy net> wrote:
> cylinder { <0,0,0>,<1,0,0>,n rotate bla*y } //correct?
> then the end point will be <sin(bla),0,cos(bla)>
I prefer:
cylinder { <0,0,0>,<1,0,0>,n rotate bla*y}
The end point will be vrotate(<1,0,0>, bla*y)
Note that your solution should be <sin(degrees(bla)), 0,
cos(degrees(bla))>, unless you specify your angles in radians. But
vrotate works for any rotation, instead of just a rotation around an
axis, so I would recommend you use it. It also makes your code easier to
figure out when you come back to it after abandoning it for a week.
Chris Huff
e-mail: chr### [at] yahoo com
> it.
Well I do swear from time to time...
Well thank you for thanking me. Looking back to all of the questions
I have answered and all of the people I have helped I am satisfied with
the contributions I have made to the POV-Ray community. At other times
I wonder if I have done enough. Was my help needed ? Were my answers
good enough ? Should I have tired harder, written more, and explained
better ? All I can really do is contribute what I can and hope that
others share what they know when they too have the opportunity to.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
It should be <sin(radians(bla), 0, cos(radians(bla)))>, isn't it ?
Assuming bla is in degrees...
Bouf.
In article <38C78FBC.E0929D84@nanterre.marelli.fr>, Bouf
Er, yes. My explanation? I was only on my second cup of coffee this
morning. :-)
Oh, another way to do it(assuming you are using MegaPOV) would be
vtransform(<1,0,0>, rotate bla*y). Not necessarily the best way in this
case, but if you are using several transformations in a row, you can
#declare them as a transform and use that to modify both the object and
the vector. Like this:
#declare Vect = < 1, 0, 0>;
#declare Trans =
transform {
rotate, scale, translate...
object {MyObj
transform {Trans}
#declare startVect = vtransform(Vect, Trans);
Chris Huff
Especially if you happen to be a doctor or a dentist.
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Subject: Re: difficult questions (for me anyway)
Date: 9 Mar 2000 11:01:17
Message: <38c7cacc@news.povray.org>
Ken <tyl### [at] pacbell net> wrote:
: We are here to help not criticize.
I apologize.
It's just that sometimes the RTFM-mentality hits me when something looks
so simple (to me) in the manual.
Date: 9 Mar 2000 11:44:14
Message: <38c7d4de@news.povray.org>
Thanks again for your help.
The trig solution should have been obvious but for some reason didn't occur
to me in this context.
Vector math is something we did not study 45years ago when I was at school
and I have had little time to try and understand it since. I have learnt
allot from this discussion about vrotate and have solved my original problem
now, using both vrotate and trig.
One last point. Many of us do not work in environments full of high powered
mathematical brains and computer gurus - we rely on this news groups to help
us understand. I for one thank you for all your patience.
Mick
http://www.minda.swinternet.co.uk/index.htm
"Chris Huff" <chr### [at] yahoo com> wrote in message
news:chrishuff_99-A18175.07020309032000@news.povray.org...
> morning. :-)
> #declare Trans =
> transform {
> object {MyObj
> transform {Trans}
> Chris Huff
> Web page: http://chrishuff.dhs.org/
There is a brief visual explanation here:
http://www.spiritone.com/~english/cyclopedia/vrotate.html
hopefully this helps. If not, please send me osme feedback so I can make
this more useful for people
Josh
Mick Hazelgrove wrote:
> > Or more easier with vrotate().
> Please explain, for me and for other maths disadvantaged pov users!
Josh English
eng### [at] spiritone com
There are some vector math examples (in the animations section, I believe). I
really recommend anybody who has trouble understanding the maths render those
examples since, as you say, they are worth a 1000 words.
Heck, they even helped me understand what vdot does. No verbal explanation had
managed to do that.
Perhaps similar examples should be added to encompass more functions. The one
Mick mentioned seems a common requirement.
Margus
Oh yeah, forgot. That's such a pain in the arse.
What's so great about radians anyway? That the arc length of one radian is
the radius? Some magical property of pi? Why do mathematicians always seem
to prefer radians to degrees?
___ _______________________________________________
| \ |_ <dav### [at] faricy net> <ICQ 55354965>
|_/avid |ontaine http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
David Fontaine wrote in message <38C833B5.111745F5@faricy.net>...
Because calculus works out much better if you use radians.
Mark
