POV-Ray : Newsgroups : povray.advanced-users : Triangle Mesh Server Time
30 Sep 2024 12:13:53 EDT (-0400)
  Triangle Mesh (Message 1 to 10 of 11)
Subject: Triangle Mesh
Date: 18 Feb 2000 13:52:28
Message: <38ad94ec@news.povray.org>
How are users creating multiple triangles from data sets
Can't seem to find utilities for this.
Subject: Re: Triangle Mesh
Date: 18 Feb 2000 14:11:31
Message: <chrishuff_99-58E055.14124618022000@news.povray.org>
In article <38ad94ec@news.povray.org>, "David Vincent-Jones"
Can you provide more information about what exactly you want? And for
which platform?
Are you looking for a conversion utility which converts from some other
mesh format to POV-Ray format? Or something that will take data and
output triangles? If the latter, what format is the data in?
Chris Huff
e-mail: chr### [at] yahoocom
Date: 18 Feb 2000 16:03:57
Message: <38adb3bd@news.povray.org>
I would like to put in a list of 3D points and finish up with a set of
triangles that I can massage into a mesh_triangle set.
I would like to try this as an alternate to gridding the data and then
displaying as a height_field.
I am using MS Windows and see several progs for Unix based systems but not
MS.W.
David
Chris Huff <chr### [at] yahoocom> wrote in message
news:chrishuff_99-58E055.14124618022000@news.povray.org...
> which platform?
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 18 Feb 2000 16:50:35
Message: <38ADBE55.761056E9@pacbell.net>
It sounds like you are describing what is known as a point cloud. Each
reference point of data is given as a single 3D coordinate rather than
a list of vertices that most 3D formats use. I too have looked for
software that will accomplish what you are looking for and have found
a definate lack of software to do this on any platform. I am sure it is
possible to write software to do this but you would have to have a strict
set of rules for the point cloud so that the software can logically connect
the individual points for you. Otherwise you will get a meaningless
jumble of triangles.
Good Luck,
Date: 18 Feb 2000 17:17:14
Message: <8EDEE0097seed7@204.213.191.228>
> Otherwise you will get a meaningless jumble of triangles.
No triangle solution, but thinking loud;
-How about using a blob with a component at each coordinate?
-Could a pointcloud be turned into a datafile that can be used to make an
isosurface object (i_dat3d library) in MegaPov?
Ingo
Date: 18 Feb 2000 17:33:06
Message: <icetOGE8Jlj6Q1XbnRzJ5HQzEzvF@4ax.com>
On Fri, 18 Feb 2000 13:03:33 -0800, "David Vincent-Jones"
>MS.W.
Can you please send me the links to these Unix programs (or the
programs if you can fit everything in under 500k)? I'll check and see
if any of them does what you want, then maybe recompile it for Win32
if I can.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 18 Feb 2000 19:55:10
Message: <38ade9ee@news.povray.org>
Peter;
Here are 2 that may be worth looking at.
I used a search on 'Delaunay and Triangular ' to find them.
The second item has quite a good description of the process
ftp://ftp.ncsa.uiuc.edu/SGI/MinMaxer
http://www.cs.cmu.edu/~quake/triangle.html
David
Peter Popov <pet### [at] usanet> wrote in message news:icetOGE8Jlj6Q1...
not
> >MS.W.
> if I can.
> Peter Popov
> pet### [at] usanet
> ICQ: 15002700
Date: 19 Feb 2000 06:54:33
Message: <doOuOEwhNvJYPL8QZtAhzPLfxJqZ@4ax.com>
On Fri, 18 Feb 2000 16:54:38 -0800, "David Vincent-Jones"
>Peter;
I'll look into it.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 21 Feb 2000 09:10:19
Message: <qqm4sb2ir3o.fsf@schlatt.fmi.uni-konstanz.de>
Ken <tyl### [at] pacbellnet> writes:
The reconstruction of a surface from a point cloud is subject to current
research. That's why it is not too surprising that no free all purpose tool
exists for this task.
http://thomas.willhalm.de/ (includes pgp key)
Date: 21 Feb 2000 10:40:26
Message: <38B14C14.9E5FCD7E@merlin.net.au>
> Thomas
The closest thing is probably finding a 'convex hull'
You could look at
http://www.geom.umn.edu/software/qhull/
PoD.
