POV-Ray : Newsgroups : povray.advanced-users : Isosurface problem. Server Time
18 May 2026 12:59:29 EDT (-0400)
  Isosurface problem. (Message 11 to 12 of 12)
Subject: Re: Isosurface problem.
Date: 15 Feb 2000 18:23:09
Message: <Cid3XCAW+Zq4Ewap@econym.demon.co.uk>
Wasn't it Simen Kvaal who wrote:
>The thought struck me too, but I have so little expirience with such things
>you know.
>There are several other things that I find odd, too. Such as: What's the
>difference between:
>    #declare Tooth = function { niceonehere }
>    isosurface { Tooth(x, y, z) }
>and
>    isosurface { Tooth }
My experiments show that the first one defaults to method 2 and the
second to method 1.
>Another one:
>isosurface {
>        function {
>                Tooth(x, y, z) + 0*SomeDistortion(x, y, z)
>versus:
>isosurface {
>        function {
>                Tooth(x, y, z) //+ 0*SomeDistortion(x, y, z)
>(see my other post.)
Those both default to method 2,  but you didn't use that syntax in your
other post, you used
 isosurface {
        function {
                <expression> //+ (0.00*Noize)
which defaults to method 1 when the // is present. ("Noize" is undefined
in the version of Megapov I'm using (0.3)).
Mike Williams * ##
Gentleman of Leisure
Date: 16 Feb 2000 12:41:11
Message: <38aae137@news.povray.org>
>second to method 1.
Yes, but when I declare my own function and _don't_ pass x, y and z as
paramaters, what then?
Noize was jus a name I invented at that time. The point was that I get
different results using the // and _not_ using them! Weird!
Simen.
