POV-Ray : Newsgroups : povray.advanced-users : Finding point outside circles Server Time
16 Mar 2026 17:18:46 EDT (-0400)
  Finding point outside circles (Message 1 to 10 of 19)
Subject: Finding point outside circles
Date: 10 Feb 2000 15:20:41
Message: <38a31d99@news.povray.org>
I have N number of circles, all with a radius of 1.
A point P is located *inside* *all* the circles.
How do I find the point Q that is as close as
possible to P, but which is located *outside* *all*
the circles?
Thanks in advance,
Rune
Updated January 24: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Subject: Re: Finding point outside circles
Date: 10 Feb 2000 16:06:49
Message: <38a32869@news.povray.org>
I can imagine he solution. I write this as I think, and cannot guarantee a
working solution; only a thorough (?) analysis of the problem.
Preliminary analysis: By a circle we mean not the 2d curve, but the 2d space
_enclosed_ by this curve, but not _including_ the curve. Thus, any point
_inside_ a circle with radius 1 lies _closer_ than 1 units from the centre
of the circle. The point _just outside_, however, will lie exactly one unit
away from the centre.
If you have N circles (not spheres, but the 2d counterpart) in the plane,
with radius 1, you can see this:
We are seeking a point _no farther_ than 1 units away from one well chosen
circle. This, because there are a finite number of circles, and there will
always exist a point that is outside them all.
the vector a_n which points from the centre of circle number n to the point
P (insode) in question, has an absolute value _less_ than 1. The vector b_n,
pointing to the point Q _outside_all of the circles, however, has an
absolute value _equal_ to one.
Examining the perimeter of the union of the circles, we find m candidates to
the point Q, and these lie in the corners where circles meet. There are a
maximum of N+1 such points, but it can be less. (I cannot prove this easily,
but see for yourself; it must be true). Thus we have reduced the amount of
possible solutions from one zillion to N+1, and that's not bad.
It sould not be difficult to locate those points, checking the distance to P
and chose the one(s) closest.
In fact, I think there might be a connection between the closes point and
the vector sum of the vectors b_n and the sum a_n, but I'm not sure.
Hope this was useful/laughable/fun.
Simen.
Rune skrev i meldingen <38a31d99@news.povray.org>...
>the circles?
>Thanks in advance,
>Rune
Date: 10 Feb 2000 16:40:43
Message: <38a3305b@news.povray.org>
space
Yes.
b_n,
Yes, where sphere N is one specific circle, not any circle.
to
easily,
I don't think so. If there's holes in the area covered by the spheres there
will be more points, I think.
Besides, How do I find out which intersection points are on the perimeter of
the union? I guess testing all the points are the only way?
One more question: How do I find these points where the circles intersect?
Thanks for your help!
Greetings,
Rune
Date: 10 Feb 2000 16:45:44
Message: <38A3312B.4BF2B6E0@faricy.net>
But you said the point is inside *all* of the circles. I am only hypothesizing
here, but I believe if such a point does exist there can be no holes.
___     ______________________________________________________
 | \     |_                 <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine               http://www.faricy.net/~davidf/
"Sitting on a cornflake, waiting for the van to come" -Beatles
Date: 10 Feb 2000 17:42:15
Message: <38A33DEB.23710331@my-dejanews.com>
Just assume that Q lies on a circle of radius 2 centered at P.
> the circles?
> Thanks in advance,
> Rune
Date: 11 Feb 2000 02:00:24
Message: <38a3b388@news.povray.org>
hypothesizing
That was my point too. If such a hole exist, then at least two circles
doesn't overlap, thus no common point for _all_ the circles exist.
5k.
Date: 11 Feb 2000 05:06:26
Message: <qqmael859zx.fsf@schlatt.fmi.uni-konstanz.de>
"Simen Kvaal" <sim### [at] studentmatnatuiono> writes:
No. Without loss of generality we assume that all circles are pairwise
different. (If two circles are identical, we remove one of them.)
Since there exists a point that lies inside all circles, two of them
intersect in two points. There are N circles and therefore N*(N-1)/2
unordered pairs of circles. This may lead to up to N*(N-1) intersections.
The closest intersection point may not be the correct solution. It may
lie inside another (third) circle.
A simple but time consuming algorithm may work like this:
1. For every pair of circles find the two intersection points and collect
   them in a list L.
2. For every circle C
3.     For every intersection point P in L
4.        If P is inside C
5.           Remove P from the list L
6. Find the closest point in L
http://thomas.willhalm.de/ (includes pgp key)
Date: 11 Feb 2000 10:56:07
Message: <38a43117@news.povray.org>
But most of these intersections are not interesting, because they are
obscured by other circles. On the _perimeter_ of the big buch of circles,
there are a maximum og N+1 points to check.
Try to draw circles on a paper so that all of them overlap at some point,
and see what happens. How many points around the edge of the figure do you
need to count?
to P
No, because all the intersection points in question are outside all the
circles. (See above.)
Date: 11 Feb 2000 15:29:15
Message: <38a4711b@news.povray.org>
>exist, then at least two circles doesn't
>the circles exist.
Oops... you're right.
I mixed some thoughts together...
Greetings,
Rune
Date: 11 Feb 2000 15:29:20
Message: <38a47120@news.povray.org>
>interesting, because they are obscured
>the big buch of circles, there are a
Why N+1? Why not just N?
If N=5, there would be 5 circles and
thus 5 of these points.
Please explain :-)
Greetings,
Rune
