POV-Ray : Newsgroups : povray.advanced-users : Finding point outside circles Server Time
18 May 2026 12:58:29 EDT (-0400)
  Finding point outside circles (Message 11 to 19 of 19)
Subject: Re: Finding point outside circles
Date: 12 Feb 2000 07:04:52
Message: <38A54C69.F1849540@numerik.uni-kiel.de>
Here we go, I did a little testcase.
I don't know if it is as bad as can be, but it gives some hints on error
cases for algorithms.
The point Q is close to P. (P is not depicted, but just choose one). It
is closer as 2 and even closer as 1/2 (that was a bug in my mind :-))
Not all intersections are outside of circles. And I got N+1 outer
intersections. I don't know if I can have more.
So much for the test case.
Oh and take care in your algos, that you don't know the order of the
circles.
Axel
Download 'circle1.png' (3 KB)
Preview of image 'circle1.png'
Date: 12 Feb 2000 10:48:49
Message: <38a580e1@news.povray.org>
>Why N+1? Why not just N?
>If N=5, there would be 5 circles and
>thus 5 of these points.
Thinking about it, I realize that it is N number of points; you're
absolutely right! For some reason I counted wrong... :O.
Simen.
Date: 13 Feb 2000 08:18:42
Message: <38a6af32@news.povray.org>
Serge LAROCQUE wrote:
>Ok, so now, calculate all the points of intersection,
>store in a list somehow. Check them for being
>interior points with the inequality
>(x-xi)^2+ (y-yi)^2 < 1 for each circle, where (xi,yi)
>is the centre of circle i. Discard any points that
>satisfy the the inequality. You are left with all the
>exterior points. Calculate their distance from P and
>pick the nearest one.
Yes, I too have found that that's the only way.
Now I just need to know how to calculate all the
points of intersection. How do I do that?
Greetings,
Rune
Updated January 24: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Date: 13 Feb 2000 11:10:15
Message: <38a6d767@news.povray.org>
Given two circles with centres c1 and c2, both radius 1, the points of
intersection is the points p that satisfy:
(Note that vectors and points are essentially the same, so we can for
example take the dot product of two points by summing the products of the
components (i.e. coordinates.))
||p-c1|| + ||p-c2|| = 2
This should be fairly straightforward, i think.
5k.
Date: 13 Feb 2000 11:18:18
Message: <I9imOLF7N67+JFYPlLA6OyWpG+3m@4ax.com>
On Sun, 13 Feb 2000 14:19:32 +0100, "Rune" <run### [at] inamecom>
>Greetings,
>Rune
For each two circles, solve the system:
(X-X1)^2+(Y-Y1)^2=R1^2
(X-X2)^2+(Y-Y2)^2=R2^2
where the two circles have centers (X1,Y1) and (X2,Y2) and radii R1
and R2, respectively. The system will have no real roots if they do
not intersect, one double real root if they touch, two distinct real
roots if they intersect and infinitely many solutions if they
coincide.
Peter Popov
pet### [at] tagpovrayorg
ICQ: 15002700
Date: 13 Feb 2000 11:36:22
Message: <q5ndask0esqr4e5od8no4l7ogef6vhclg2@4ax.com>
On Sat, 12 Feb 2000 13:04:57 +0100 Axel Hecht <ah### [at] numerikuni-kielde>
  Hi, Axel. Can you please cancel the post with the binary attachment
(image)? This is a text group. The preferred method is to post text in
this group and mention where to find the image in p.binaries.images.
  Thanks for your help in keeping some organization to the articles on
this server.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 14 Feb 2000 03:25:26
Message: <38a7bbf6@news.povray.org>
Aha! Simen has found a solution to this part of the problem.
Concider the two circles, whose radi are1 and centres c1 and c2.
Now, translate and rotate the system so that c1 lies at <0, 0> and c2 lies
on <x, 0>, simply by letting c1' = 0 and c2' = c2 - c1, and rotating
with -theta, where tan theta = c2'.y/c2'.x.
Now, there are two points of intersection if the circles overlap (or one if
they are just "kissing".) By simple geometric judgement and using the
Pythagorean Theorem, we obtein the two intersections:
<x/2, sqrt(1-x^2/4)> and <x/2, sqrt(1-x^2/4)>
Now, rotate these points with +theta, and add c1, and you have the points of
intersection between the two circles.
5k.
Date: 14 Feb 2000 07:41:33
Message: <qqmemagvtvm.fsf@schlatt.fmi.uni-konstanz.de>
"Simen Kvaal" <sim### [at] studentmatnatuiono> writes:
> >No. Without loss of generality we assume that all circles are pairwise
> >different. (If two circles are identical, we remove one of them.)
> >Since there exists a point that lies inside all circles, two of them
> >intersect in two points. There are N circles and therefore N*(N-1)/2
> >unordered pairs of circles. This may lead to up to N*(N-1) intersections.
> But most of these intersections are not interesting, because they are
> obscured by other circles. On the _perimeter_ of the big buch of circles,
> there are a maximum og N+1 points to check.
> Try to draw circles on a paper so that all of them overlap at some point,
> and see what happens. How many points around the edge of the figure do you
> need to count?
The problem is that you don't know in advance which intersection points
are on the boundary. You must have a look at all intersection points and
decide whether it is inside another circle. Such a brute force algorithm
requires cubic run time.
However in this case, there is a better way than a brute force algorithm:
Since all circles have the same perimeter, it should be enough to have
a look at intersection points of consecutive circles, thus considering
only N intersection points.
Sorting the circles is possible in O(n log n) time. This dominates the
(asymptotic) run time.
http://thomas.willhalm.de/ (includes pgp key)
Date: 23 Feb 2000 12:14:12
Message: <38B41465.C4D2EB3A@hotmail.com>
Hi Rune and Peter
> >Greetings,
> >Rune
> coincide.
> Peter Popov
> ICQ: 15002700
I just had to see if I could solve the problem of finding these points
of
intersections without having to solve the above equation system.
(or maybe I did solve it without knowing it ? ;-)
Here is my graphical (and numerical) POV-Ray solution.
It can be used to solve the problem for intersection of spheres
(3D-problems)
or intersection of circles (2D-problems).
Best regards,
Tor Olav Kristensen
mailto:tor### [at] hotmailcom
// Finding the points where two spheres (or circles) meet. By Tor Olav
Kristensen.
#version 3.1;
// Data for the spheres (3D) or circles (2D)
// The z co-ordinate in the sphere centres can be set to zero for a
// 2D-problem/solution in the XY-plane.
// If such an 2D solution is needed: Also select UpVector = z
// Note: If you choose the two spheres to have the same centre, then
// my solution will not work. If they also have the same radius, there
// will have infinitely many "intersections", else they will have none.
// It would however be simple to test for these cases before my code
// is used.
#declare Radius1 = 3.5;
//#declare Center1 = <-3, -2, 0>; // 2D-problem
#declare Center1 = <-3, -2, 2>; // 3D-problem
#declare Radius2 = 3;
//#declare Center2 = <1, -5, 0>; // 2D-problem
#declare Center2 = <1, -5, 1>; // 3D-problem
// My attempt to solve the problem
#declare Vector1to2 = Center2 - Center1;
#declare Distance = vlength(Vector1to2);
#declare C = (Radius1*Radius1 - Radius2*Radius2 + Distance*Distance)/
             (2*Distance);
#declare BetweenPoint = Center1 + C*vnormalize(Vector1to2);
#declare TR = Radius1*Radius1 - C*C;
//#declare UpVector = z; // for 2D-problem
#declare UpVector = <1, 3, -2>; // example for 3D-problem
// Note: Do not choose an UpVector that is parallel to Vector1to2
#declare SideVector = vcross(Vector1to2, UpVector);
#if (TR > 0)
  #declare SideVector = sqrt(TR)*vnormalize(SideVector) // Resizing
  #declare InterSection1 = BetweenPoint + SideVector;
  #declare InterSection2 = BetweenPoint - SideVector;
#else
  #if (TR = 0)
    #declare InterSection = BetweenPoint;
#declare NewUpVector = vcross(SideVector, Vector1to2);
// I use this NewUpVector instead of UpVector just to make sure
// that I have an "Up"-vector that is perpendicular to the line
// between the two spherecentres.
// Should I have used vcross(Vector1to2, SideVector) instead?
// Maybe not: The numerical results seems to be the same.
// But the graphical view changes to "the other side"
// Graphical illustration of the problem
sphere { Center1, Radius1 pigment { color Green } }
sphere { Center2, Radius2 pigment { color Cyan  } }
plane {
  NewUpVector, 0
  translate BetweenPoint
  pigment { color Yellow }
// Graphical illustration of my proposed solution
#if (TR > 0)
  sphere { InterSection1, 0.8 pigment { color Red  } }
  sphere { InterSection2, 0.8 pigment { color Blue } }
#else
  #if (TR = 0)
    sphere { InterSection, 0.8 pigment { color Magenta } }
// Note: A more correct graphical solution for a the 3D-problem
// would be to put a torus along the "circle of intersection" of
// the two spheres. Its major radius would then equal sqrt(TR)
// It's center should be at BetweenPoint. You can find an image here:
// http://www.crosswinds.net/~tok/Sphere2Sphere04.jpg
// Text output of the proposed solution to the debug window
// Press Alt M when parsing to view this text output
#macro PrintVector(Vector)
  #debug concat("<", str(Vector.x, 0, -1), ", ",
                     str(Vector.y, 0, -1), ", ",
                     str(Vector.z, 0, -1), " >")
#end // macro PrintVector
#if (TR > 0)
  #debug concat("\nFirst  intersection: ")
  PrintVector(InterSection1)
  #debug concat("\nSecond intersection: ")
  PrintVector(InterSection2)
#else
  #if (TR = 0)
    #debug concat("\nIntersection: ")
    PrintVector(InterSection)
  #else
    #debug "\nThere are no intersections"
  #end // if
#end // if
#debug "\n"
// Just my macros for axes
// X-axis is red
// Y-axis is green
// Z-axis is blue
#macro Arrow(StartPoint, EndPoint, Radius)
  #local a = Radius*3;
  #local b = Radius*2;
  #local c = Radius;
  #local Dirv = vnormalize(EndPoint-StartPoint);
  merge {
    difference {
      cone {
        EndPoint, 0,
        EndPoint-(a+b)*Dirv, Radius+c
      cone {
        EndPoint-a*Dirv, Radius,
        EndPoint-(a+2*b)*Dirv, Radius+2*c
    cylinder {
      StartPoint, EndPoint-a*0.999*Dirv, Radius
#end // macro Arrow
#macro Axes(Size)
  #local Thickness = Size/40;
  union {
    object {
      Arrow(-Size*x, Size*x, Thickness)
    object {
      Arrow(-Size*y, Size*y, Thickness)
    object {
      Arrow(-Size*z, Size*z, Thickness)
#end // macro Axes
Axes(5)
#declare CameraPosition = BetweenPoint + 3*(Radius1+Radius2)*
                          vnormalize(NewUpVector);
#if (TR > 0)
  light_source { CameraPosition + (Radius1+Radius2)*SideVector, White }
  light_source { CameraPosition - (Radius1+Radius2)*SideVector, White }
#else
  light_source { CameraPosition, White }
  location CameraPosition
  look_at BetweenPoint
