POV-Ray : Newsgroups : povray.advanced-users : Macros acting strange Server Time
14 Oct 2025 19:06:41 EDT (-0400)
  Macros acting strange (Message 1 to 10 of 11)
Subject: Macros acting strange
Date: 28 Mar 2000 14:43:02
Message: <38E10B3A.7C6D3308@stud.ntnu.no>
This code shows something I found the other day: a macro (intp) wich returns a
number, affects the x-value when used in some vector expressions.
At first I thought it was a bug in MegaPov, but it also shows up in
POV-Ray 3.1e
#macro intp(X,X1,Y1,X2,Y2)
    (Y2-Y1)/(X2-X1)*X - (Y2-Y1)/(X2-X1)*X1 + Y1
#macro Print(V1)
    #local v1=V1*<1,1,1>;
    #render concat(
        str(i,1,0),": <",
        str(v1.x,2,1),", ",
        str(v1.y,2,1),", ",
        str(v1.z,2,1),">\n"
#declare var1=.1;
#declare var2=1;
// this one adds var1*x
#declare i=0;
#while (i<=3)
    Print( x + (y+z)*intp(i, 0, var1, 3, var2)  )
    #local i=i+1;
#render "\n"
// this is fine
#declare i=0;
#while (i<=3)
    Print( <1, intp(i, 0, var1, 3, var2), intp(i, 0, var1, 3, var2)>  )
    #local i=i+1;
#render "\n"
//this is fine
#declare i=0;
#while (i<=3)
    Print( x + (y+z)*.3*i  )
    #local i=i+1;
#render "\n"
//this is also fine
#declare i=0;
#while (i<=3)
    Print( <1, .3*i, .3*i>  )
    #local i=i+1;
Subject: Re: Macros acting strange
Date: 28 Mar 2000 16:15:06
Message: <38E11FBD.8BEAA009@online.no>
Hei Kyrre!
If you put parenthesis around your macro result it will
stop acting strange.
Like this:
    ((Y2-Y1)/(X2-X1)*X - (Y2-Y1)/(X2-X1)*X1 + Y1)
The third parameter; Var1 (Y1) passed to your macro
will not be multiplied with (y+z) if you don't do this.
(If you omit the parenthesis, then Var1 is promoted to
a vector before it's added to a vector.)
Tor Olav
mailto:tor### [at] hotmailcom
> POV-Ray 3.1e
> #end
> #declare var1=.1;
> #declare var2=1;
> #declare i=0;
> #while (i<=3)
>     #local i=i+1;
> #end
> #render "\n"
Date: 28 Mar 2000 16:32:20
Message: <38E124D8.33B8DF84@stud.ntnu.no>
Ah! Thanks. It's so easy to treat something like intp() like a function.
sig
Tor Olav Kristensen wrote:
> Hei Kyrre!
> Like this:
> #end
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
> > POV-Ray 3.1e
> > #end
> > #declare var1=.1;
> > #declare var2=1;
> > #declare i=0;
> > #while (i<=3)
> >     #local i=i+1;
> > #end
> > #render "\n"
Date: 28 Mar 2000 16:51:21
Message: <38E12832.F9273777@online.no>
Hei igjen.
This part of the expression would also have been
promoted to a vector if you hadn't passed 0 for the
second argument (X1) to the macro:
(Y2-Y1)/(X2-X1)*X1
It actually adds var1*(x + y + z)
(or <var1, var1, var1>)
Tor Olav
Btw.: Here's a slightly simpler macro to do the same:
    ((Y2-Y1)/(X2-X1)*(X-X1)+Y1)
Date: 29 Mar 2000 04:07:15
Message: <38e1c7c3@news.povray.org>
You have to remember that a macro is _not_ a function. A macro is a
substitution string. The body if the macro is inserted in the place of
the call as-is.
  So, for example this:
#macro Sum(X, Y)
  X+Y
#declare result = 2*Sum(3,4);
will result in:
#declare result = 2*3+4;
  The right way of doing the macro is, of course:
#macro Sum(X, Y)
  (X+Y)
  Now the result will be:
#declare result = 2*(3+4);
Date: 30 Mar 2000 14:41:44
Message: <38E3ACD4.9A9E063B@online.no>
> the call as-is.
Hmmm...
If that is true, then why does this not work?
#macro Test(ss)
  { ss, ss, ss }
#declare TestArray = array[3] Test(2)
Tor Olav
Date: 31 Mar 2000 03:56:00
Message: <38e4681f@news.povray.org>
Tor Olav Kristensen <tto### [at] onlineno> wrote:
: If that is true, then why does this not work?
  I have no idea.
Date: 31 Mar 2000 06:09:50
Message: <chrishuff_99-F3724F.06120931032000@news.povray.org>
> > the call as-is.
> Hmmm...
Er, well...it should work.
I tried some other combinations, putting the brackets outside the macro,
enclosing each value with parenthesis...it still doesn't work. When I
put a #debug statement in the macro, I found the macro is never called.
Maybe you should compose a bug report. This looks like a real bug.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Date: 31 Mar 2000 08:02:16
Message: <38e4a1d8@news.povray.org>
I suppose that it's because a macro call is not expected after the
declaration of an array and thus it never gets parsed.
  Probably a mistake.
Date: 31 Mar 2000 08:42:23
Message: <38E4AA17.61D172C5@online.no>
>   Probably a mistake.
For me it seems to be parsed in some strange way, because I
get this error message:
  { <----ERROR
Test.pov: error: object or directive expected but { found instead.
Would the "{" appear in the error message if the macro
wasn't ever parsed?
Tor Olav
Btw: Does anyone know if it's possible to copy (and paste)
a text string from the error message window in the
Windows POV?
