POV-Ray : Newsgroups : povray.advanced-users : look_at for objects? Server Time
15 Jun 2026 17:45:31 EDT (-0400)
  look_at for objects? (Message 1 to 10 of 14)
Subject: look_at for objects?
Date: 16 Mar 2000 14:33:23
Message: <38D160CC.B42C5D7B@ibm.net>
Hello,
Is there any macro available that will perform on an object the same
function as the look_at command does in a camera?
In other words, I have an object at <0,0,0> and oriented in the +z
direction, and I wish to perform an x-rotation then a y-rotation so that
the object is now pointing at a given point (as in the look_at point for
the Camera).  I've been using John VanSickle's Reorient macro, but in
some cases the object receives an undesireable z-rotation so that it
becomes tilted wrong.
I've been banging my head for a while about this, any help would be
appreciated!
Andrew C
Subject: Re: look_at for objects?
Date: 16 Mar 2000 16:01:08
Message: <38D14BFE.BCDF6EA5@ma.usb.ve>
Andrew Clinton wrote:
> ...and I wish to perform an x-rotation then a y-rotation ...
The instruction
rotate <xrot, yrot, 0>
will do the work.
See the povdoc section 4.3.1.3.
I hope this will help you
Alberto
Date: 16 Mar 2000 16:54:04
Message: <38D181BD.BE20D01C@ibm.net>
No,no, thats not the problem.  I mean that I am given a *point* (like a
look_at point), not the rotation values.  Here is a camera:
    location <0,0,0>
    look_at <1,-2,3>
Pov-ray will automatically rotate the camera so that it is pointing at
<1,-2,3> while maintaining +y as the up direction (ie the horizon will
still be horizontal).  What I need to find is the x-rotation and
y-rotation that are needed to properly align an object rather than a
camera to point at the point (because look_at can't be used with
objects!).  It is very important that the object not change its z- tilt
for my purposes.
Your right, rotate <xrot,yrot,0> will work but I need the rotation
values first!
Thank you,
Andrew C
> The instruction
> will do the work.
> Alberto
Date: 16 Mar 2000 17:12:05
Message: <38D15B46.4CEFD082@faricy.net>
Yes!
// Reorient from <0,0,1> to p
#macro PointTo(p)
   #if (0+p.x=0 & 0+p.y=0 & 0+p.z=0)
      #local RotX=0;
   #else
      #local RotX=-atan2(p.y,sqrt(pow(p.x,2)+pow(p.z,2)))*180/pi;
   #if (0+p.x=0 & 0+p.z=0)
      #local RotY=0;
   #else
      #local RotY=atan2(p.x,p.z)*180/pi;
   rotate <RotX,RotY,0>
or
//reorient from vector 1 to vector 2
#macro reposition2(vec1,vec2)
   #if (vlength(vec1)=0)
      #render "Warning: reposition2 initial vector length is zero.\n"
   #if (vec1.x=0 & vec1.z=0)
      #local RotY=0;
   #else
      #local RotY=atan2(vec1.x,vec1.z)*180/pi;
   #local RotX=asin((vec1.y)/vlength(vec1))*180/pi;
   rotate -RotY*y
   rotate RotX*x
   #if (vlength(vec2)=0)
      #render "Warning: reposition2 final vector length is zero.\n"
   #if (vec2.x=0 & vec2.z=0)
      #local RotY=0;
   #else
      #local RotY=atan2(vec2.x,vec2.z)*180/pi;
   #local RotX=asin((vec2.y)/vlength(vec2))*180/pi;
   rotate <-RotX,RotY,0>
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 16 Mar 2000 17:14:16
Message: <38D15BC9.6E466D29@faricy.net>
David Fontaine wrote:
> Yes!
I'm so enthusiastic cause nobody beat me to it with one of VanSickle's
macros... ;-)
Date: 16 Mar 2000 18:15:36
Message: <38D194D6.C2DE1E1B@ibm.net>
Thank you :)
This is how I'm going to make the Megapov motion blur work - move the
objects backwards rather than move the camera forwards!
Andrew C
> > Yes!
> macros... ;-)
Date: 16 Mar 2000 18:19:22
Message: <38D16ACC.469F9197@hotmail.com>
> Yes!
8< Snip
> #macro PointTo(p)
>       #local RotX=0;
>    #else
8< Snip
Just a little suggestion for the last of these lines:
#local RotX = degrees(-atan2(p.y, vlength(p*(x+z)));
Regards
Tor Olav
mailto:tor### [at] hotmailcom
Date: 16 Mar 2000 18:36:02
Message: <38D1704D.86519C22@ma.usb.ve>
Ahhh...
You may try this
#macro PointTo(p)
  #local Rd = vlength(p);
  #if(Rd = 0)
    #local   Rotx = 0;
    #local   Roty = 0;
  #else
    #local   Rotx = 180*asin(p.y/Rd)/pi;
    #if(p.z = 0)
      #local Roty = 0;
    #else
      #local Roty = 180*atan2(p.x, p.z)/pi;
  rotate <Rotx, Roty, 0>
Alberto
Date: 16 Mar 2000 19:05:45
Message: <38D175AC.93FF07A2@hotmail.com>
Alberto wrote:
> Ahhh...
> You may try this
> #macro PointTo(p)
>   #if(Rd = 0)
>     #local   Rotx = 0;
>     #local   Roty = 0;
>   #else
>     #if(p.z = 0)
>       #local Roty = 0;
>     #else
>     #end
>   #end
> #end
> Alberto
If that works then maybe this also works:
#macro PointTo(p)
  #local RotVector = <0, 0, 0>;
  #if(Rd != 0)
    #local RotVector = x*degrees(asin(p.y/Rd));
    #if(p.z != 0)
      #local RotVector = RotVector + y*degrees(atan2(p.x, p.z));
  rotate RotVector
But I haven't tested it...
Tor Olav
Date: 17 Mar 2000 07:30:46
Message: <38D22658.60BC678F@erols.com>
> Hello,
My matrix page at
  http://users.erols.com/vansickl/matrix.htm
has some sample code that may be useful.
John
