POV-Ray : Newsgroups : povray.advanced-users : Mirage Server Time
16 Mar 2026 15:28:40 EDT (-0400)
  Mirage (Message 1 to 4 of 4)
Subject: Mirage
Date: 16 Mar 2000 00:58:53
Message: <38D07821.92979244@hotmail.com>
This seems to be the appropriate group
How would it be possible to create a mirage in any current or old
version of POV-Ray (I imagine that the interior of an object could
modify the direction a ray is traced backwards ??)
Subject: Re: Mirage
Date: 16 Mar 2000 02:51:53
Message: <n5HQOC6KhugVTNYVWcRouktn4iBJ@4ax.com>
Refraction is surely one way to do it. Keep in mind that most if not
all types of mirages are caused by the variable ior of hot vs. cold
air, and in POV there's no variable ior. One can however use a distant
transparent plane with refraction and a varying normal to achieve if
not a mirage then at least a heat wave effect. Another idea is to use
the camera ray perturbation feature in POV. One way or the other
you'll have to fake it.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Subject: Re: Mirage
Date: 16 Mar 2000 03:36:18
Message: <38d09d02@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote in message
news:n5HQOC6KhugVTNYVWcRouktn4iBJ@4ax.com...
A possibility might be to use a 'texture_map' in POV-Ray 3.0*, but not in 3.1
(using the #version directive doesn't work).
Before refraction was moved into the 'interior' statement it was possible to use
ior in finishes and thus also in texture maps to 'average' or otherwise pattern
the refractions together.  This would make for a variable refraction.
Subject: Re: Mirage
Date: 17 Mar 2000 00:35:38
Message: <38d1c42a@news.povray.org>
Peter Popov wrote in message ...
You can fake a continuously variable IOR by stacking a number of very thin
boxes with the desired IORs.  This will approximate a variable IOR, but will
take an extremely long time to render.
Mark
