POV-Ray : Newsgroups : povray.advanced-users : Turbulence Server Time
15 Jun 2026 23:55:36 EDT (-0400)
  Turbulence (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Turbulence
Date: 24 Feb 2000 00:05:18
Message: <38B4BBAD.E134BD5F@pacbell.net>
Ron Parker wrote:
> It's possible, probably not using an existing method, and it would be
> very useful.  I'd love to have that functionality.
Glad I am not alone in seeing a positive use for something like this.
>  Something like this, perhaps, to produce the
> zigzag pattern you mentioned:
> warp {pigment {marble} y}
Could you break this down to help me understand how this might produce
a zigzag pattern ? I'm so easily confused...
Date: 24 Feb 2000 08:00:39
Message: <38B52BF3.72B9F8B9@peak.edu.ee>
Well, on a XZ plane and a gradient x I'd say a warp{pigment{marble} x} would
produce the zig-zag pattern.
Each point of the gradient would be warped along the specified axis (here x),
and the amount of warping would depend on the current value of the warp pattern
(marble = gradient z triangle_wave which goes min>max>min>... along the z axis).
Several image manipulation programs have filters that use this prince; I know
GIMP has one, so does HLA (height_field generator). It allows for many kinds of
interesting effects.
Margus
Date: 24 Feb 2000 08:10:34
Message: <chrishuff_99-1163ED.08115724022000@news.povray.org>
In article <38B52BF3.72B9F8B9@peak.edu.ee>, Margus Ramst
> x} would produce the zig-zag pattern. Each point of the gradient
> would be warped along the specified axis (here x), and the amount of
> warping would depend on the current value of the warp pattern (marble
> axis).
Hmm, since here a pigment's color_map is being used to calculate
vectors...why not use a pattern and add a "vector_map"? It would add one
keyword, but would leave a cleaner syntax.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 24 Feb 2000 08:20:23
Message: <38B53093.E6119BE1@peak.edu.ee>
In what Ron proposes, values would be used to calculate only vector lengths.
But it would indeed be more flexible to allow similar syntax as in other maps,
e.g. warp{pigment{marble vector_map{[0,z][1,<0,1,1>]}}}
Margus
Date: 24 Feb 2000 08:21:17
Message: <38b5304d@news.povray.org>
And a much more interesting syntax as well.  But it'd actually require
two keywords, because the warp would have to have a name (though I suppose
we could reuse the pattern keyword... it doesn't get used much these days.)
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 24 Feb 2000 08:26:04
Message: <38b5316c@news.povray.org>
marble is gradient x triangle_wave.  From the docs:
  Earlier versions of POV-Ray did not allow you to change wave types. Now that
  wave types can be changed for most any pattern, the distinction between
  marble and gradient x is only a matter of default wave types.
Applying the warp I suggested to an xy plane would yield the desired result by
the mechanism you've explained quite well.  Applying the warp you suggested
to an xz plane would give you something different and potentially very
interesting, because it's offsetting in the direction of the change in value.
Date: 24 Feb 2000 08:32:11
Message: <38B53356.7CA89475@peak.edu.ee>
Of, damn. I hate giving misinformation.
My only excuse is that I don't use marble.
Margus
Date: 24 Feb 2000 15:24:32
Message: <chrishuff_99-815B47.15255724022000@news.povray.org>
In article <38B53093.E6119BE1@peak.edu.ee>, Margus Ramst
> lengths.
> maps,
I don't think "pigment" should be used, since we aren't even controlling
a color any more...maybe "pattern" or "displacement"?
Chris Huff
Date: 25 Feb 2000 04:08:54
Message: <38B64606.AD89FF5B@pacbell.net>
I was thinking about the marble pattern itself and not the type of wave
form it represents. This clears it up nicely thank you.
What would you get if you applied a color list pattern to the warp ?
Might be interesting...
Date: 25 Feb 2000 06:36:45
Message: <chrishuff_99-C0CD93.06381025022000@news.povray.org>
In article <38B64606.AD89FF5B@pacbell.net>, lin### [at] povrayorg
I think it would look the same as a texture_map with that list pattern,
using the same texture for each component, just translating them the
appropriate amount. For example: the texture applied to all the "red"
squares of checker would be translated by the same amount, and the same
goes for all the "green" squares.(using red and green to indicate the
different sets of squares)
Chris Huff
