POV-Ray : Newsgroups : povray.advanced-users : Square roots of negative numbers in isosurfaces? Server Time
18 May 2026 12:57:26 EDT (-0400)
  Square roots of negative numbers in isosurfaces? (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Square roots of negative numbers in isosurfaces?
Date: 14 Jan 2000 00:02:47
Message: <chrishuff_99-A0DA74.00030614012000@news.povray.org>
In article <387EA67E.7CE91E84@faricy.net>, David Fontaine
<dav### [at] faricynet> wrote:
> What I think POV *should* do is not include these areas in the graph. Say
> I
> want to graph a hemisphere on my TI-89, I do x^2+y^2+z^2=1,
> z^2=-x^2-y^2+1,
> z=sqrt(1-x^2-y^2), and graph it and it gives me my hemisphere, and the
> area
> *outside* the hemisphere is ignored (not rendered) because it is
> sqrt(neg).
> Because if people want it to work the other way they can always just make
> it sqrt(abs(x)) instead of sqrt(x).
I think this might be difficult to do, because the isosurface is solved
by sampling the function at different points. I don't see how it could
be done.
Then again, it is after midnight now, it is probably just that I am
tired and not thinking straight.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 14 Jan 2000 17:10:49
Message: <387F9E1B.F3DF1811@my-dejanews.com>
But the point is that pov is doing SOMETHING.  If it finds a definite
isosurface for a mathematically undefined region of space, then povray is in
reality not computing the given function, but converting it to some defined
function. Or there is an error in how it has defined some functions.
perhaps
    x^a = sign(x)^int(a) * abs(x)^a
because
    noise3d(x^3.1, y, z)
gives "something" for negative values of x !
I'm not complaining as much as striving to solve the mystery . . .
> > I
> > z^2=-x^2-y^2+1,
> > area
> > sqrt(neg).
> be done.
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 14 Jan 2000 17:16:00
Message: <387F9F51.19F25191@my-dejanews.com>
Yet another possibility, as I jokingly suggested, is that pov has "discovered"
solutions to these functions, and mathematicians and programs like Lotus 123 are
"wussies" for refusing to give an answer to these unorthodox
questions..............
> perhaps
> because
Date: 14 Jan 2000 17:21:35
Message: <chrishuff_99-19A28A.17215614012000@news.povray.org>
In article <387F9E1B.F3DF1811@my-dejanews.com>,
> in reality not computing the given function, but converting it to some
> defined
But if it stops when it attempts to sample at an undefined spot, there
could be defined areas that would be missed or rendered incorrectly.
Maybe there should be a "strict_math" option. If strict_math is on, then
it will perform the solving operation as it usually does, and then test
the function at that point using standard math to see if it is defined
at that point. If it is defined, then count it as an intersection,
otherwise skip it. That way, the undefined areas would be removed(by a
kind of customized clipping). And older isosurfaces would still work
properly, either with the addition of "strict_math off" or by having
strict_math default to off.
Chris Huff
Date: 14 Jan 2000 21:20:24
Message: <FslWUEAg43f4EwTB@econym.demon.co.uk>
Wasn't it David Fontaine who wrote:
>What I think POV *should* do is not include these areas in the graph. Say I
>want to graph a hemisphere on my TI-89, I do x^2+y^2+z^2=1, z^2=-x^2-y^2+1,
>z=sqrt(1-x^2-y^2), and graph it and it gives me my hemisphere, and the area
>*outside* the hemisphere is ignored (not rendered) because it is sqrt(neg).
That might be possible when using the function as an isosurface, but
such a function can also be used as a pattern for a pigment or normal.
When a function has no solution in a region of space you could ignore it
if you're using that function to define a surface, but what could you do
if there's a point where the surface exists but the pigment and/or
normal doesn't. E.g.
sphere {0,1
            function {noise3d(x^0.5/K, y/K, z/K)}
            colour_map{[0 rgb <1,0,0>][1 rgb <1,1,0>]}
        normal {
Mike Williams + #
Gentleman of Leisure
Date: 15 Jan 2000 22:45:49
Message: <38813C69.D04DBC9F@faricy.net>
> sphere {0,1
>         pigment {
>         normal {
Well it's up to the user to make a function that doesn't do that. It could issue
a warning and replace it with zero or something.
Date: 17 Jan 2000 07:04:08
Message: <38830469.C475282D@my-dejanews.com>
No problem, but pov is doing SOMETHING.  It makes up its own definition in the
undefined areas. That's the mystery.
what is x^a?
> Chris Huff
Date: 17 Jan 2000 11:54:25
Message: <38834975.C6C381E5@ij.net>
> what is x^a?
    x to the power a or exp( a * log(x) )
    If a = 2 then it would be x*x
Date: 17 Jan 2000 16:20:44
Message: <388386DC.48C2398@my-dejanews.com>
> > what is x^a?
Nope.  You cannot take the ln(x) of a negative x! Therefore, that's NOT what povray
is doing!  My guess is
x^a= sign(x)^int(a)* abs(x)^a .
My re-writing of the function is "defined" for all values of x and a, whereas x^a is
NOT.
Again, I hound this point not to attack the giants whose shoulder we stand on--pov
developers--but to have fun at solving a mathematical mystery : what IS pov doing?
Date: 17 Jan 2000 16:25:00
Message: <3883870C.729B3B58@pacbell.net>
Perhaps only Mr. Suzuki can answer this question...
