POV-Ray : Newsgroups : povray.advanced-users : array-macro Server Time
16 Mar 2026 17:18:44 EDT (-0400)
  array-macro (Message 1 to 7 of 7)
Subject: array-macro
Date: 28 Dec 1999 14:11:26
Message: <386908a5.2657716@news.povray.org>
Tying to create a macro that use a array I've a problem.
Having the following code
#declare Numberofdigits = 10
#declare digits = 1,20,10,4,5,3,87,8,21,4
How can I put this variable number of digits into an array?
Roland
Subject: Re: array-macro
Date: 28 Dec 1999 15:06:50
Message: <jerry-38E2F4.12064828121999@news.povray.org>
In article <386908a5.2657716@news.povray.org>,
>Roland
#declare myDigits = array[Numberofdigits] {
Jerry
Date: 29 Dec 1999 00:30:25
Message: <38699c88.1090748@news.povray.org>
>>Roland
>Jerry
Thanks Jerry, but I knew that answer. The meaning is that Pov does the
job and not me.  How can I Pov make read the numbers and put them into
the array
Date: 29 Dec 1999 05:29:28
Message: <3869e288@news.povray.org>
Roland Vansteenkiste <rol### [at] pingbe> wrote:
: How can I Pov make read the numbers
  From where?
Date: 29 Dec 1999 13:04:30
Message: <ZQsRLCARlba4EwbF@econym.demon.co.uk>
>>>Roland
>>Jerry
>the array
If you'll accept digits as a string, then you can extract values from
its substrings. As it stands, I don't know what the incorrect
is intended to mean.
#declare Numberofdigits = 10;
#declare digits = "1,20,10,4,5,3,87,8,21,4"
#declare MyArray = array[Numberofdigits]
// It's much easier if there's an extra comma at the end
// so we don't have to check for running off the end of the string
#declare MyDigits = concat(digits,",")
#declare C = 1; // start of substring
#declare K = 1; // end of substring
#declare N = 0;
#declare Comma = asc(",");
#while (N < Numberofdigits)
  #while (asc(substr(MyDigits,K,1)) > Comma)
    #declare K=K+1;
  #declare MyArray[N] = val(substr(MyDigits,C,K-C));
Mike Williams #
Gentleman of Leisure
Date: 30 Dec 1999 01:29:49
Message: <386B25FF.F3A0ECC7@ij.net>
> the array
    external file I guess. Haven't looked into it. A looping readlin (or
comma recognizing routine) with an onerror flagging no more numbers. I
presume there is an onerror flag. (If not, make it a suggestion.)
Date: 31 Dec 1999 01:16:35
Message: <386c4ae1.1270526@news.povray.org>
On Wed, 29 Dec 1999 07:33:37 +0000, Mike Williams <mik### [at] nospamplease>
>>>>Roland
>>>Jerry
>>the array
>#declare N = 0;
>    #declare K=K+1;
>  #end
>#end
Thanks Mike. Thats what I was looking for
Roland
