POV-Ray : Newsgroups : povray.advanced-users : Simple math question Server Time
2 Nov 2024 11:25:34 EDT (-0400)
  Simple math question (Message 1 to 10 of 18)
Subject: Simple math question
Date: 23 Dec 1999 00:54:22
Message: <3861B710.22DAAEEE@faricy.net>
What are the equations for surface area and volume of a torus,
*including* torii with minor>major radius?
Subject: Re: Simple math question
Date: 23 Dec 1999 12:54:58
Message: <386261EE.3C4AF3A9@stud.ntnu.no>
I don't remember that calculus stuff very well, but since no one's
helped you yet, me and my pocket calculator had a go at it:
volume:
  a:=2*int( sqrt(r^2-(x-R)^2) ,x,0,R+r )  // 1/2 torus cross-section
  int( a*R,theta,0,2*pi )                 // object of revolution
> R*pi*( pi*r*abs(r)+2*R*sqrt(r^2-R^2)+2*pi*asin(R*abs(1/r))/180*r^2 )
Odds are this is wrong.. Not sure about line 2.
area:
  c:=2*sin(R/r)*r 			// part of arc inside torus
  int( (2*pi*r-c)*R ,theta,0,2*pi )
> -4*r*R*pi*(sin(R/r)-pi)
or something
sig.
> Homepage: http://www.faricy.net/~davidf/
> ___     ______________________________
>  | \     |_       <dav### [at] faricynet>
>  |_/avid |ontaine      <ICQ 55354965>
Date: 23 Dec 1999 15:48:24
Message: <38628A92.374CC2C2@stud.ntnu.no>
Darn. Both are wrong. Setting R=r should be equal to a sphere, but it's
not:
A!=-4*pi*r^2( (sin(1)-pi )
V!=2*pi^2*r^3
> volume:
> area:
> or something
> sig.
Date: 23 Dec 1999 22:56:52
Message: <3862ED00.9ED42E31@faricy.net>
It's easy enough for normal torii, but spindle torii are a pain in the arse!
Well I don't need it that badly, I can work it out another way.
Date: 23 Dec 1999 22:56:56
Message: <3862ef08@news.povray.org>
http://mathworld.wolfram.com/T/Torus.html
Haven't checked it, but the formulas there probably won't
take r > R into consideration, so you will have to subtract
the overlapping areas/volumes.
Gerald
ger### [at] aonat
Date: 23 Dec 1999 23:32:23
Message: <3862F552.607C2F97@faricy.net>
It's more complicated than that, because with major=0 you should get a
sphere but the only equations I've seen return 0 for both.
Date: 24 Dec 1999 00:19:15
Message: <3A458755.4B549746@tapestry.tucson.az.us>
Well, I had this whole big thing typed out explaining step by step how I
found the formulas (so you could solve similar problems by yourself),
but Netscape crashes and I lost everything, so I'm just going to give
you the answers rather than type it all out again.
These formulas only work for a spindle tours.  r1 is the major radius
and r2 is the minor radius.
V = 4/3*pi*(r2^2-r1^2)^(3/2)
A = 4*pi*r2*sqrt(r2^2-r1^2)
I'm pretty sure that these are correct.  I hope this helps.
Date: 24 Dec 1999 00:46:25
Message: <386308b1@news.povray.org>
Sigmund Kyrre Aas wrote in message <38628A92.374CC2C2@stud.ntnu.no>...
>not:
>V!=2*pi^2*r^3
Setting R=r should give you the area for two spheres, thus:
A=8*pi*r^2
V=(8/3)*pi*r^3
Mark
Date: 24 Dec 1999 06:18:51
Message: <38635697.A81303A8@stud.ntnu.no>
'fraid not.
Date: 24 Dec 1999 13:10:50
Message: <388C96A7.88E72C87@tapestry.tucson.az.us>
Well, except for a really whopping error I made they were.
I redid my calculations and now I think I have the correct formulas:
V = 4*pi*(1/6*r1^2*sqrt(r2^2-r1^2)+1/4*pi*r1*r2^2
    -1/2*r1*r2^2*asin(-r1/r2)+1/3*r2^2*sqrt(r2^2-r1^2))
A = 4*pi*(r1*r2*acos(-r1/r2)+r2*sqrt(r2^2-r1^2))
Now, if I didn't make a typo, those should work much better.
