POV-Ray : Newsgroups : povray.advanced-users : math quiz Server Time
24 Feb 2025 13:35:19 EST (-0500)
  math quiz (Message 1 to 5 of 5)
Subject: math quiz
Date: 7 Dec 1999 15:29:34
Message: <384D6DDA.51142915@stud.ntnu.no>
Any idea how I can rotate a torus for instance so it's aligned with a
vector? This doesn't quite do the trick, but illustrates what I'm after
(and how stupid I am):
rotate
   x*degrees(atan2(n.z,n.y))+
   y*degrees(atan2(n.x,n.z))+
   z*degrees(atan2(n.x,n.y))
Where n would be the new "normalvector" for the torus.
sig
Subject: Re: math quiz
Date: 7 Dec 1999 16:31:18
Message: <384D7C83.5A721635@spiritone.com>
There is a standard orientation macro that looks like this:
#macro Orient(v1,v2)
  #local nx = vnormalize(v2 - v1);
  #local nz = vnormalize(vcross(nx,y));
  #local ny = vcross(nz,nx);
  matrix <nx.x,nx.y,nx.z,
          ny.x,ny.y,ny.z,
          nz.x,nz.y,nz.z,
          v1.x,v1.y,v1.z>
This only works if the object "faces" the positive x axis... so you might
want to rotate your torus by 90*z before including the macro:
torus { 1, 0.25 // or whatever
            rotate 90*z
            Orient(thisvector, thatvector) }
It is possible (and I've don't it before but I don't have the file handy)
to rearrange the first three lines of the macro that will make the
rotation command unnecessary.
Good Luck
> rotate
> sig
Josh English
eng### [at] spiritonecom
ICQ: 1946299
"Stress is when you wake up screaming and realize you haven't fallen
asleep yet."
Date: 8 Dec 1999 11:45:02
Message: <384E8B06.B4EF5A47@stud.ntnu.no>
Thanks a bunch! I finally understand the transformation matrix. The
documentation isn't very good.
>           ny.x,ny.y,ny.z,
>           nz.x,nz.y,nz.z,
>           v1.x,v1.y,v1.z>
> #end
>             rotate 90*z
> Good Luck
Date: 8 Dec 1999 18:11:49
Message: <384EE5B4.3AE4265E@spiritone.com>
I pride myself on being able to explain anything, but John VanSickle explains
the Matrix better than I ever could. Take a look at
http://users.erols.com/vansickl/matrik.htm for more details
> >           ny.x,ny.y,ny.z,
> >           nz.x,nz.y,nz.z,
> >           v1.x,v1.y,v1.z>
> > #end
> >             rotate 90*z
> > Good Luck
Josh English
ICQ: 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
Date: 8 Dec 1999 19:38:53
Message: <384EF9C8.AB4F4490@xs4all.nl>
> explains
Very educational!
(http://users.erols.com/vansickl/matrix.htm)
Remco
