Noah A wrote:
> > is that tga macro easy to use? the one that makes spheres refom a tga?> i'd like to make a moditor explosion ani
I suppose you are talking about Tga Mosaic the program that will represent
a tga image using spheres or other objects as colored pixel representatives.
In which case I seem to recall the author made allowances for animating the
image and has specific command line parameters for doing so.
http://www.coe.uncc.edu/~adwoodfi/tga.html
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Ken wrote:
> > Noah A wrote:> >> > is that tga macro easy to use? the one that makes spheres refom a tga?> > i'd like to make a moditor explosion ani> > I suppose you are talking about Tga Mosaic the program that will represent> a tga image using spheres or other objects as colored pixel representatives.> In which case I seem to recall the author made allowances for animating the> image and has specific command line parameters for doing so.> > http://www.coe.uncc.edu/~adwoodfi/tga.html
P.S. Yes it is easy to use
Ken Tyler
thanks again ken
Ken wrote:
> Ken wrote:> >> > Noah A wrote:> > >> > > is that tga macro easy to use? the one that makes spheres refom a tga?> > > i'd like to make a moditor explosion ani> >> > I suppose you are talking about Tga Mosaic the program that will represent> > a tga image using spheres or other objects as colored pixel representatives.> > In which case I seem to recall the author made allowances for animating the> > image and has specific command line parameters for doing so.> >> > http://www.coe.uncc.edu/~adwoodfi/tga.html>> P.S. Yes it is easy to use>> --> Ken Tyler>> See my 700+ Povray and 3D Rendering and Raytracing Links at:> http://home.pacbell.net/tylereng/index.html
