POV-Ray : Newsgroups : povray.advanced-users : Maloc Error ? Server Time
15 Jan 2025 13:32:32 EST (-0500)
  Maloc Error ? (Message 1 to 6 of 6)
Subject: Maloc Error ?
Date: 7 Aug 1999 12:59:01
Message: <37AC6548.690BC5A6@pacbell.net>
In an attempt to store an array of points for use in Mr. Parker's torspline
macro I recieved the following error message:
From pov message window:
  #declare Pts=array[Mx]{ <----ERROR
F:\3d\twirl2.pov:81: error: Attempt to malloc zero size block (File: ..\..\TOKENIZE.C
Line: 3396).
Que Pasa ?
Ken Tyler
Older   Links Page: http://home.pacbell.net/tylereng/links.htm
Updated Links Page: http://home.pacbell.net/tylereng/bkmrk999.htm
Subject: Re: Maloc Error ?
Date: 7 Aug 1999 13:34:34
Message: <37AC6EA1.5A29187C@geocities.com>
..\..\TOKENIZE.C Line: 3396).
> Que Pasa ?
Hmmm. Seems as if Mx is 0. It needs to get a valid size before used to make an array.
Was that in
your code, or his?
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 7 Aug 1999 13:56:29
Message: <37AC72BC.B34CB8EC@pacbell.net>
> > Que Pasa ?
array.  Was that in
> your code, or his?
In my code Mx is #declared as 12. I think I have is straightened out now I was
just wondering what a maloc error was.
Ken Tyler
Date: 7 Aug 1999 17:51:40
Message: <37acaa6c@news.povray.org>
Ken <tyl### [at] pacbellnet> schrieb in im Newsbeitrag:
37AC72BC.B34CB8EC@pacbell.net...
(snip)
was
maloc stands for Memory Allocation, and is a function from C which allocates
Memory.
greetings Lars
Date: 10 Aug 1999 10:07:00
Message: <37B032A0.5C631346@inapg.inra.fr>
If you're using the latest Superpatch version 3.1g, malloc errors have been popping up
(particularly
in regular meshes) due to a bug and Ron Parker has promised a fix. If you don't use
the Superpatch, I
have no clue.
Gilles Tran
> Que Pasa ?
> Ken Tyler
Date: 10 Aug 1999 10:45:06
Message: <37b03af2@news.povray.org>
up (particularly
the Superpatch, I
>have no clue.
Those show up as coming from parse.c.  I think Ken mentioned that he had fixed
whatever was causing the problem, but I just wanted to clarify that whatever it
was, it was not due to that particular bug.
