Chris Huff <Chr### [at] compuserve com> wrote:
: Hmm, I think I will just stick to the isosurfaces. :-)
Are isosurfaces as fast as quartics?
That is a great solution... I've jsut been trying to remember how to take all
those formulas from algebra and turn them into poly and cubic statements.... I
thought it was based on the standard forms of the equaitons, but that didn't
seem to work. I'll have to look into that again
Joshua
eng### [at] spiritone com
Nieminen Mika wrote:
> The formula of an elliptical cylinder along the z-axis is the following:
> x^2/r1^2 + y^2/r2^2 = 1
> where 'r1' and 'r2' are the radiuses of the ellipse.
> What we want is this kind of cylinder which changes linearly from z=0 to
> z=1 so that in z=0 the ellipse has radiuses 'a' and 'b' and in z=1 radiuses
> 'c' and 'd'.
> This means that when z=0, r1=a and r2=b. Then r1 and r2 should linearly
> change so that when z=1, r1=c and r2=d.
> This can be expressed this way:
> r1 = a*(1-z)+c*z
> r2 = b*(1-z)+d*z
> Substituting in the above formula we get:
> x^2/(a*(1-z)+c*z)^2 + y^2/(b*(1-z)+d*z)^2 = 1
> That's it. Now we have to reduce that to polynomial form so that we can
> write the quartic. This is a quite laborious job. I will not type the
> polynom here because it's so long, but it begins this way:
> b^2*x^2 + 2*(b*d-b^2)*x^2*z + (b^2-2*b*d+d^2)*x^2*z^2 + ... and so on
> Now, to write the polynomial, we look at the table in the page 212 of the
> povray manual (the "Poly, Cubic and Quartic"-section). We place all the
> terms of the polynomial in the right places in the vector. The result is:
> quartic
> { <0, 0, 0, 0, 0, 0, 0, b*b-2*b*d+d*d, 2*(b*d-b*b), b*b,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, a*a-2*a*c+c*c, 2*(a*c-a*a), a*a, 0, 0, 0, 0,
> -(a*a-2*a*c+c*c)*(b*b-2*b*d+d*d),
> -(2*((b*d-b*b)*(a*a-2*a*c+c*c)+(a*c-a*a)*(b*b-2*b*d+d*d))),
> -(b*b*(a*a-2*a*c+c*c)+4*(a*c-a*a)*(b*d-b*b)+a*a*(b*b-2*b*d+d*d)),
> -(2*(b*b*(a*c-a*a)+a*a*(b*d-b*b))), -a*a*b*b>
> Now we only have to cut the unwanted parts out (ie. everything that is
> at z<0 and z>1) and bound with a proper object for speedup.
In article <37A02A80.FC2CCB77@panama.phoenix.net>, TonyB
<ben### [at] panama phoenix net> wrote:
> One thing I've noticed is that these 'quartics' can do some of
> the stuff that an isosurface can do. Am I correct in assuming this?
Quartics are polynomials with x, y and z as variables. When the
coordinates of a given point are plugged in the polynomial, the
polynomial evaluates to some numerical value.
If the value is zero, the point is on the surface of the object
represented by the polynomial. If the value is less than zero, the point
is inside the object. If the value is greater than zero, the point is
outside the object.
Thus the surface of the object consists of all the points in space with
which the polynomial evaluates to zero.
Henri Sivonen
hen### [at] clinet fi
http://www.clinet.fi/~henris/
