POV-Ray : Newsgroups : povray.advanced-users : Creating Spheres of Triangles Server Time
27 May 2026 17:56:46 EDT (-0400)
  Creating Spheres of Triangles (Message 11 to 20 of 20)
Subject: Re: Creating Spheres of Triangles
Date: 1 Jul 1999 21:08:04
Message: <377C1081.6959EAEA@pacbell.net>
"Lars W." wrote:
> Hi
> I wan't to construct an Sphere out of triangles ,( i know the standard
> POV-Sphere is faster and better and
> so on, but i need a trianglesphere ), does anybody know of resources, or has
> an tutorial by him self
> for doing that. it should be possible to say, how complex the sphere should
> be, and it should
> NOT look like an globe, best would be an sphere out of evenly sized
> triangles.
> thanks in advance.
> Lars Wolter
  For the record the older dos utility called geodome was perfect for this
task. If you would like a copy I could email it to you.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 1 Jul 1999 21:18:03
Message: <377C12D8.F74033DF@pacbell.net>
Ken wrote:
> "Lars W." wrote:
> > Hi
> > be, and it should
> > triangles.
> > thanks in advance.
> > Lars Wolter
> Ken Tyler
  I also have the C source for that program if anyone would rather
tinker with that for inspiration.
Ken Tyler
Date: 3 Jul 1999 15:33:30
Message: <377e658a@news.povray.org>
That would be great,  if can send me the source, it shouldn't be a Problem
to make some POV Code out of it, and if i can't get it to work, i can write
my own c-Programm creating triangle spheres.
E-Mail  mailto:lar### [at] snafude
Thanks
Ken <tyl### [at] pacbellnet> schrieb in im Newsbeitrag:
377C12D8.F74033DF@pacbell.net...
> Ken wrote:
> > "Lars W." wrote:
> > > Hi
or has
should
> > > be, and it should
> > > triangles.
> > > thanks in advance.
> > > Lars Wolter
this
> > Ken Tyler
> Ken Tyler
Date: 3 Jul 1999 15:33:31
Message: <377e658b@news.povray.org>
Thanks for the tip, i see what i can get out of the Programm that Ken sends
me, and if
it doesn't work in any way i would be happy for an example from you.
greetings Lars
Lance Birch <lan### [at] usanet> schrieb in im Newsbeitrag:
377c0f03@news.povray.org...
> >: I wan't to construct an Sphere out of triangles ,( i know the standard
> >: POV-Sphere is faster and better and
> >: so on, but i need a trianglesphere ), does anybody know of resources,
or
> has
> >: an tutorial by him self
> >: for doing that. it should be possible to say, how complex the sphere
> should
> >: be, and it should
> >: NOT look like an globe, best would be an sphere out of evenly sized
> >: triangles.
> >  Distributing objects evenly on the surface of a sphere is a non-trivial
> >task.
> >  If making a earth-looking globe (with latitude and longitude lines) is
> >enough, that's pretty easy with povray (you need some math, though).
> But the triangles won't be the same sizes right?
> If you really want to do it perfectly you can use a geosphere with a
> geodesic base type of a 20-sided icosahedron.  The facets are all equally
> sized equilateral triangles.  From there the sphere can be divided into
any
> number of segments based on multiples and divisions of the 20 faces.
> Right?
> Alternatively you could try a polyhedron base type like a tetrahedron or
> octahedron (all of which can be made as spacial spherical subdivisions)
but
> these won't look as even as the icosahedron will.
> If you want I can post an example of such an object.
> Lance.
> For the latest 3D Studio MAX plug-ins, images and much more, go to:
> The Zone - http://come.to/the.zone
> For a totally different experience, visit my Chroma Key Website:
> Colorblind - http://listen.to/colorblind
Date: 3 Jul 1999 19:22:41
Message: <377E9BB9.D800357A@ma.usb.ve>
"Edward C." wrote:
> But there are other ways to subdivide...
Of course you are right. Your answer make me think harder. Finally I arrived
to a version of your idea that creates equilateral triangles. Again I posted
the result in the povray.bin.images.
Alberto.
Date: 5 Jul 1999 09:07:52
Message: <3780AE26.A6CCE30F@ele.kth.se>
I just found a basic source code on the net that should do. I'll also
try to translate it to POV code - shouldn't be too complicated:
http://www.freenet.edmonton.ab.ca/domes/geometry.bas
Uwe.
Date: 5 Jul 1999 09:19:06
Message: <3780B0C9.A4605D1A@ele.kth.se>
Here is another link (including DOS/Win executable and C++ source):
http://www.cris.com/~rjbono/html/domes.html
Uwe.
Date: 7 Jul 1999 03:18:30
Message: <3782FF46.57ED1C57@ele.kth.se>
Trying to revive this thread...
I succeeded in translating the basic version to POV only to notice that
it only creates the symmetry triangle. However, I got back to the
basics, took out pencil and paper, did some geometry and finally I got
it:
A POV macro that does an intersection of the three triangular faced
polyhedrons (tetrahedron, octahedron, icosahedron) to any number of
splittings (also called frequency) resulting in a geodesic sphere.
Up to now the macro is still experimental and I have to add a little bit
of documentation and remove those nasty #debug messages. But then -
hopefully by the end of this week - I'll post it on this server.
What it does
  - intersects the triangular shaped faces of polyhedrons and projects
the new
    vertices on a unit sphere
  - gives back an array with the coordinates of these vertices
  - a second macro gives the resulting geodesic sphere as an object with
a native
    radius of 1 POV unit, centered at the origin
  - user-defined macros determine the shapes/objects drawn at the vertex
coordinates
    ("corners") and as the links ("edges") between each two neighbouring
vertices
  - a third macro (not yet written) is going to create a mesh structure
representing
    the triangular faces of the geodesic sphere
You can have a look at the first testpicture which I post in
povray.binaries.images under the same thread name.
Uwe.
Date: 8 Jul 1999 04:49:03
Message: <378465FE.336E88C5@ele.kth.se>
Hej Lars, hej all!
> POV-Sphere is faster and better and so on, but i need a trianglesphere )...
Here it is: my newly written (and first published) POV macro package
"geodesic.inc".
You can see a sample scene under the thread "Creating Spheres of
Triangles II) in povray.binaries.images and you can get the package
itself under the same subject in povray.binaries.utilities.
Uwe.
Date: 12 Jul 1999 12:03:32
Message: <378A11B6.782645ED@njmedicine.com>
> be, and it should
> triangles.
I created a package that will take an image in Mathematica and convert
it to povray.  I put some examples up at
http://members.wri.com/davida/povlink/povlink.html
The first three are the same surface of revolution object and the last
is a torus.  The the sphere, the torus can also be created by povray,
but I those to do it in Mathematica and convert it.
-Dave
