POV-Ray : Newsgroups : povray.advanced-users : Hardcore povrayer test Server Time
28 May 2026 00:54:25 EDT (-0400)
  Hardcore povrayer test (Message 7 to 16 of 66)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Hardcore povrayer test
Date: 14 Jun 1999 11:20:19
Message: <37651db3@news.povray.org>
On Mon, 14 Jun 1999 17:45:19 +0300, Margus Ramst wrote:
>I don't really agree that one has to be a C programmer to be a "hardcore
>POVer"
I agree, in principle.  But you have to admit that someone who has
added their own keywords certainly qualifies as hardcore.  So I
guess it's sufficient but not necessary.  Note, though, that most
of the assertions I suggested have little or nothing to do with
programming.
By the same token, the original purity test has lots of questions
about illegal drug use.  Those of who might normally score low
on that test can't because they have at least a little respect for
the law and/or their bodies.  Is that fair?  Probably not.  But it's
their test, and they can put whatever they want on it.
I guess I don't have room to argue, since I hold the record score
so far anyway. I thought of another assertion, though: "You're on
the POV-Team."  Most of those folks can't get the patching points,
but they should get lots of points for giving us official versions.
Date: 14 Jun 1999 12:53:19
Message: <3765340D.3EDF14A@inapg.inra.fr>
Got a score of 9. I'm an underscore povrayer !
G.
Nieminen Mika wrote:
>   The hardcore povrayer test.
>   Read the allegations below. For each allegation that is true in your
> case, you receive the amount of points in parentheses at the end of the
> line. The maximum point amount is 78. Please be honest.
>   My personal score is 22.
Date: 14 Jun 1999 13:02:55
Message: <37653596.2D548AFB@aol.com>
Heh-heh, little side note here: I once wanted to start using 'gloss' and 'gloss_used'
instead of 'phong' and 'phong_size' so I hacked at the code simply replacing those
words. Biggest mistake I ever made when I realized I couldn't redefine them to be
compatible with other script files. I only used POV-Ray this way a very short while
and
I almost never got back on track again. So a bit of friendly advice here, only "add"
keywords, don't replace them. Oh, and Nieminen M., scanning over that "test" leads me
to
believe I better not even try to see what I'd score, I hate failure.
> programming.
 mailto://inversez@aol.com?Subject=PoV-News
Date: 14 Jun 1999 14:06:31
Message: <376544a7@news.povray.org>
Alex Vandiver wrote in message <37651C47.231A621E@tiac.net>...
>Under Programs > Gnu Emacs > Emacs, obviously!
Yeah, OK, I was afraid somebody would point this out. But my actual point
here was that POVWin (and POVMac?) users don't need to configure Emacs to
have syntax highlighting et al.
>>>Does it bother you that nothing shows up?
Argh! It's questions like these that remind me why I despise M$
troubleshooters :)
Margus
Date: 14 Jun 1999 14:07:05
Message: <376544c9@news.povray.org>
Ron Parker wrote in message <37651db3@news.povray.org>...
I cannot argue with this. However, in my mind the ability to overcome
certain limitations with nothing but innovative POV code has equal value.
Not only does that require inventiveness, but also great expertise with the
program at hand.
I am by no means questioning the freedom of the test maker. But if you wish
to compile a test that gives objective results, that's damn difficult. I
know by personal experience.
Margus
Date: 14 Jun 1999 14:27:47
Message: <376549a3@news.povray.org>
>program at hand.
Indeed.  I tend to try to avoid patching the source as much as possible,
too, believe it or not, if I think the current solution is adequate.  For
example, I saw no need for a keyword to auto-tile a texture by flipping
it on all axes when we already had a perfectly serviceable repeat warp.
Then there's that "hexagon-shaped tiles" thread from a while back, and
the perennial "object oriented POV script" thread.  And one I haven't
weighed in on and will probably catch some flak over... I see no need
for a replacement for #declare and #local -- If you don't like the extra
verbiage, write a preprocessor.  I probably wouldn't even have added
the #spline code to the superpatch if I hadn't had the explicit goal of
adding ALL available patches (which I haven't achieved and probably
never will.)
But there are some things you just can't do with POV script, and being
able to add them to the renderer, or at least understand why that can
or can't be done (as, for example, you and Ken seem to) is a valuable
skill for any truly hardcore POV user.
Date: 14 Jun 1999 15:09:30
Message: <37655378.A7060BD7@fv.aetec.ee>
How about softcore one? E.g. one can count, to how many VFAQ questions
he/she can answer?
I don't dare to take this test, as I am afraid that I get negative
result, as I did with IQ test...
Oh, smiley too ;-)
Date: 14 Jun 1999 15:29:08
Message: <37655744.445516B8@xs4all.nl>
I scored 0, or at least I expected to after question #20 or so.
I guess I must never show my face here again (so to speak).
Ciao!
Remco
Date: 14 Jun 1999 19:49:26
Message: <376594BB.642C04D1@powersurfr.com>
i got many of them but not the cammera in non hollow object hehehe :) but i
wouldn't say i'm hard core and adding a key word isn't that big of a deal really
> 1. You have participated in the IRTC and got to the top 20 best images. (2)
> 2. You have won a price in the IRTC. (3)
> 3. You have made bicubic patches by hand (and they worked as you expected). (2)
> 4. You have made a program which outputs bicubic patches. (1)
> 5. You have made big triangle meshes by hand. (1)
> 6. You have used a poly object bigger than 4th degree. (1)
> 7. You have calculated the polynomial for that poly object by yourself
>    (instead of just trying random values). (2)
> 8. You know the format of a PCM file. (1)
> 9. You have made one by hand. (1)
> 10. You have made a program which outputs a df3 file and used it in a
>     scene. (1)
> 11. You know what a df3 file is. (1)
> 12. You have made a patch for povray. (3)
> 13. Your patch is included in the superpatch or at least it's popular. (2)
> 14. Your patch will probably be included in povray 3.5. (2)
> 15. You have made a popular tool for povray. (2)
> 16. You have used every object type, every camera type, every light source
>     type, every media type, etc. and know how to use them. (2)
> 17. You remember the terms of the torus-shaped quartic so that you could
>     type the polynomial at any time. (2)
> 18. You understand perfectly the table at page 212 of the povray 3.1 manual
>     and use it to create your poly objects. (2)
> 19. You know what does 'sturm' mean and how it's calculated. (2)
> 20. The intensity multiplier curves and light fading functions in the light
>     source section in the povray manual are very clear and you understand
>     them perfectly and you actually use them to choose your light source
>     types. (2)
> 21. You understand how photon mapping works (at algorithm level). (1)
> 22. You have found the 'average normal bug' by yourself in a povray version
>     previous than 3.1e. (1)
> 23. You know exactly what was causing it. (2)
> 24. You never include the povray include libraries (like colors.inc) because
>     they slow parsing, but always define your colors, textures, etc by
>     yourself. (1)
> 25. You only use the png format when working with povray. (1)
> 26. You always use it with alpha channel. (1)
> 27. It's very easy to you to make slope maps and actually you often use
>     them to make your textures. (1)
> 28. You know what the 'use_index' keyword is used for without looking at
>     the manual. (1)
> 29. You understand the matrix transformation and you can write them by
>     hand. (2)
> 30. You know how to calculate the matrix from any number of consecutive
>     transformations (translate, scale, rotate). (1)
> 31. You have set up emacs with povray enhancements (like automatic indentation
>     and syntax highlighting) by yourself. (1)
> 32. You can list all the povray reserved keywords without looking at the
>     manual. (2)
> 33. You could make all the Chris Colefax's includes and macros by yourself
>     if you wanted. (3)
> 34. You use frequency, phase, octaves, omega and lambda without problems
>     when creating your own textures. (1)
> 35. You can tell what does each one of them do (without looking at the
>     documentation). (1)
> 36. You understand the scattering function pictures in the media section of
>     the documentation. (1)
> 37. You remember all the keywords that can be put in a global_settings
>     block. (1)
> 38. You know what does they mean and how to use them. (1)
> 39. Making good-looking radiosity images is not a problem to you. (1)
> 40. You remember all the built-in float and vector identifiers. (1)
> 41. You use all the vector and string functions without problem. (1)
> 42. Macros, arrays and file-IO directives are a piece of cake. (1)
> 43. You never get the "camera is inside non-hollow object" warning. If you
>     ever get it, it's absolutely intentional. (1)
> 44. You have made a modeller for povray. (3)
> 45. You often debug your povray code using the text message streams. (1)
> 46. You can easyly calculate the camera parameters when you want to put a
>     box right in front of the camera so that it completely and exactly fills
>     the viewing area. (1)
> 47. You scored in each one of the previous allegations. (10)
> main(i,_){for(_?--i,main(i+2,"FhhQHFIJD|FQTITFN]zRFHhhTBFHhhTBFysdB"[i]
> ):5;i&&_>1;printf("%s",_-70?_&1?"[]":" ":(_=0,"\n")),_/=2);} /*- Warp -*/
Date: 14 Jun 1999 23:38:14
Message: <3765C9EF.34F1588@Kopp.com>
But I'll change it if I want to!  :-)  hehehe.  Of course, I'll have to
release a second fix for it before I finally get it working correctly,
but that's only becuase I'm still learning how the tokenizer works and
I messed things up a bit with my original implementation.
-Nathan
