POV-Ray : Newsgroups : povray.advanced-users : Text Object Problems Server Time
17 Mar 2026 00:32:58 EDT (-0400)
  Text Object Problems (Message 1 to 10 of 12)
Subject: Text Object Problems
Date: 5 May 1999 12:22:59
Message: <37306253.0@news.povray.org>
Does anyone know what it is about certain fonts that prevents POV from
reading them properly??
I have a dingbat font that I'm trying to use to create an object (logo) in
an image, and although POV seems to work just fine with the majority of the
fonts on my system, there are a few that POV just can't seem to read.  (I
get boxes instead of the symbol I was expecting when using those fonts.)
Note, no other software I have has problems with these fonts, not even
Moray, which I'm using as a modeler.  The wireframe shows up exactly as I
expected in Moray, but when I render, I get the box instead of the symbol.
Any info appreciated.
ZuluNiner
(aka Calin/Runesinger)
ZuluNiner at fuckyou dot co dot uk
Subject: Re: Text Object Problems
Date: 5 May 1999 13:34:33
Message: <37307293.DC9FA0F5@pacbell.net>
> ZuluNiner
  It has mainly to do with the windows version from my understanding and the
amount of work it would take to fix it is more than the team is willing to
put into to it right now. It is mainly fonts that go above the lower 128
characters mark. If you are intent upon using these fonts in pov and don't
mind using a patched version of Pov-Ray there is a patch available that
address the unicode fonts issue.
  Take a look here for more information on the patch and the problems
it was made to fix.
http://www.geocities.com/SiliconValley/Network/4453/unipatch/
Ken Tyler
mailto://tylereng@pacbell.net
Date: 5 May 1999 14:56:44
Message: <3730865c.0@news.povray.org>
*sigh*
Thanks for the attempt, Ken.  But All this does is give me error messages
(Wrong editor DLL version.)
And besides, the symbol I'm trying to use in the font in question is mapped
to the character 'h' so it should be affected by this issue.
ZuluNiner
Ken <tyl### [at] pacbellnet> wrote in message
news:37307293.DC9FA0F5@pacbell.net...
in
the
(I
I
symbol.
> > ZuluNiner
the
> it was made to fix.
> Ken Tyler
Date: 5 May 1999 15:00:35
Message: <37308743.0@news.povray.org>
Oddly enough, though.  I tried ignoring the errors and running the scene,
anyway, and it rendered properly.
Hmm.
Thanks for the tip.
ZuluNiner
ZuluNiner <ZuluNiner*@*fuckyou.co.uk> wrote in message
news:3730865c.0@news.povray.org...
> *sigh*
mapped
> ZuluNiner
(logo)
> in
of
> the
> (I
fonts.)
as
> I
> symbol.
> > > ZuluNiner
> the
to
don't
> > it was made to fix.
> > Ken Tyler
Date: 5 May 1999 17:53:59
Message: <3730afe7.0@news.povray.org>
ZuluNiner wrote in message <3730865c.0@news.povray.org>...
>*sigh*
this is the editor dll it's talking about. I'm assuming the patched version
was based
on pov 3.1 a, b, c or d and you are using pov 3.1 e.
there was some comment about it in povray.windows if you are interested,
otherwise
you can edit in the official version and just use the patched version to
render.
The photon patch and the superpatch versions have the same problem.
Gail
* gsh### [at] monotixcoza              * ERROR: COFFEE.COM not found  *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
   My Software never has bugs, It just develops random features
Date: 12 May 1999 18:15:30
Message: <3739ef72.0@news.povray.org>
Another thing you might try instead of a patch is to type
your dingbat character in about 300pt or something, do a
screen shot and save the image as a POV-heightfield
compatible image like gif.
The rest should speak for itself, but I'll tell it anyway.
Make a heightfield object in pov and use the image of the
character as a heightfield. Scale to fit with the other text
Might be worth a try
Julius
object (logo) in
majority of the
seem to read.  (I
those fonts.)
Date: 13 May 1999 15:55:54
Message: <373b203a.0@news.povray.org>
That's what I ended up doing (before I got the response about the patched
POV version.)
It's just kind of frustrating that a feature I waited for  awhile doesn't
quite work right, you know.  Font definitions would just give MUCH smoother
edges than heightfields.
ZuluNiner
Julius Klatte <jku### [at] hotmailcom> wrote in message
news:3739ef72.0@news.povray.org...
> Julius
> object (logo) in
> majority of the
> seem to read.  (I
> those fonts.)
Date: 14 May 1999 20:11:43
Message: <373cadaf.0@news.povray.org>
Is the difference really noticable if you use a high-res
image in a smoothed heightfield?
Date: 15 May 1999 12:21:43
Message: <373d9107.0@news.povray.org>
If I remember correctly, almost horizontal heightfield surfaces are not
smooth even when the "smooth" keyword is used.
Maybe the problem could be solved if the letter is dark gray on black
instead of white on black. Then you could skale it afterwards.
Greetings,
Rune S. Johansen
My POV-Ray 3D Gallery, the POV Desktop Theme,
and the compiled list
"you know you have been raytracing too long when..."
at http://hjem.get2net.dk/rsj
Date: 16 May 1999 09:19:35
Message: <373EB7D5.D5C60843@aol.com>
Think you meant to say vertical instead of horizontal as in hf aspects.
Perpendicular to the plane of the heightfield in other words. And I
believe you may be right about the unsmooth quality of such. Smoothing
goes from one pixel square to the next *across* the face of the hf, so the
vertical or perpendicular surfaces are always potentially a large distance
from each other the sharper the edge is.
Hmmm, and now that I've done said that... smoothing will go parallel to
the plane of the hf at least.
> Greetings,
> Rune S. Johansen
 mailto://inversez@aol.com?Subject=PoV-News
