POV-Ray : Newsgroups : povray.advanced-users : A Simple Lamp Shade ? Server Time
27 May 2026 18:58:55 EDT (-0400)
  A Simple Lamp Shade ? (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: A Simple Lamp Shade ?
Date: 4 May 1999 08:37:00
Message: <372EDB50.C6BC0C10@pacbell.net>
Ph Gibone wrote:
> Another workaround would be to use the dome generator with a
> base=hypocycloid or epicycloid
> and many sides.
> Philippe
  I followed your advice and tried the Dome generater program. After about
15 different tests/renders/rejections I have yet to find a shape that comes
close to what I am hoping for. Perhaps the master could supply me with a
couple of examples of what to enter in the different fields so that I may
learn from his wisdome ?
  On a side note:
  One undesirable characteristic of the Dome program is that it is producing
a lot of degenerate triangles. You might think about adding a degenerate
triangle testing/removal feature in the program to eliminate these. I had
one file with over 350 degenerate triangles and that is a lot to have to edit
out of the file by hand. Especialy in files that are over 1+ megs in size.
I am not sure how to implement such a routine but there are many here
that I am sure could help you with that. It is a common problem for triangle
generating utilities and the fix I believe is an easy one to add.
 On a side-side note:
 For some reason I am now mentally calling the Dome program the Domenator.
Resistance is futile. You will be Domenated !
Ken Tyler
mailto://tylereng@pacbell.net
Date: 4 May 1999 18:16:51
Message: <372f63c3.0@news.povray.org>
I will as soon as tomorrow
>  On a side note:
producing
edit
triangle
I'm currently working on a few "inside features" degenerated traiangles
removal is one of them. BTW you get a warning and don't have to remove them
by hand (I never did).
I like it, even if I can feel your irony :-)))
Philippe
Date: 5 May 1999 02:56:23
Message: <372fdd87.0@news.povray.org>
The enclosed image (very quick and dirty, no AA, no good texture... just to
show you) is defined by
Base = EpiCycloide
Slope = Droite-Droite
Windows = Sans
To be honnest, this image has been done with *MY* version of the domenator
:-} (didn't I send it to you ?) where you can choose more parameters and so
the sort of cone given by the previous definition has it's head, (sorry, too
much bloody, I meant top) cut off (as you know, meshes are not good in CSG).
Here I used a v in the range 0.5 to 1 and then scaled by 2 in the up
direction.
>  On a side note:
producing
edit
triangle
Very easy : cross product is the answer (will be done as soon as I can)
Philippe
Download 'LampShade.jpg' (8 KB)
Preview of image 'LampShade.jpg'
Date: 5 May 1999 21:34:31
Message: <3730E310.519BF23F@pacbell.net>
> Base = EpiCycloide
> Windows = Sans
> direction.
  Even this is not exactly what I am looking for. The pattern in the image
you attached is only using a half wave from what I can see and I want
a full sine wave pattern.
Yours looks like this:
    __        __
and I am trying to get this:
       __            __
__/          \__/          \__
Picture to yourself both of the above samples with nice smooth curves that
striaght lines simply do not do justice to.
  I have hacked out a method that uses an open cone object and then clip
it in half. I use two of these one the inverse of the other. Then it's a
simple (ha ha) translate and rotate routine with a while loop to completes
the shape. There are a few hidden challenges doing it this way but the
results are looking acceptable once the parameters are setup right.
>> It is a common problem for triangle generating utilities and the
 Glad to here that it is something you can fix with reletive ease.
Thanks for your help and your continued support.
Ken Tyler
Date: 6 May 1999 02:40:33
Message: <37312b51.0@news.povray.org>
>    __        __
>       __            __
>__/          \__/          \__
Change the "epicycloid" base to "napperon" and you'll get it ! If I can find
a few minutes today I'll post a small image
You can't miss !
It is done : i'm testing it before releasing
Uncle Ken thankful to me ? My 3d life's fullfilled :-} (in fact not 100%
joke, I really have great respect and admiration for your knowledge and for
the way you share it, thanks Mr Ken)
Philippe
Date: 6 May 1999 03:00:47
Message: <3731300f.0@news.povray.org>
I took the time (in fact a few minutes), here the base is "Napperon"
Philippe
Download 'LampShade2.jpg' (7 KB)
Preview of image 'LampShade2.jpg'
Date: 6 May 1999 05:03:42
Message: <37314C4C.CC48C06F@pacbell.net>
> Philippe
  Now your cookin". That is indeed much closer to that which I have been
endeavoring to produce.
Thank you sir.
Ken Tyler
Date: 6 May 1999 05:06:58
Message: <37314D10.D44B603B@pacbell.net>
I will accept this challenge.
Superb !
> Philippe
 Ah gee. (blush).
Ken Tyler
Date: 6 May 1999 10:08:35
Message: <37319453.0@news.povray.org>
[pictures clipped]
Ken, was there something in my include file that didn't work for you?  It
should have generated something very like what you're looking for, with
the added benefit of double illumination.  If you can't figure it out, just
tell me the dimensions you're looking for and I'll make the necessary
modifications for you.
Date: 11 May 1999 07:51:37
Message: <373762D4.70C36E7D@pacbell.net>
Ron,
  Sorry it took so long for me to get to your suggestion but I aviod
patch object unless I can control them in a modelling environment.
 So any way I downloaded your source last night and after a bit of work
isolated the ridged part of the cap. After a few modifications and a
total lack of comprehension of what exacly your source is doing I don't
believe that it will work as structured and my lack of ability to control
it's overall shape is limiting. The angle or taper of the shape is not
steep enough and I am not particularly happy with the straight skirt or
it's length at the top (or bottom depending on orientation) of the shape.
  It is a very nicely modelled bottle cap however and I have had enough
suggestions and a few successful attempts of my own that I just don't
need another lamp shade at the point in time. I have around 10 different
designs for one lamp and I think that is enough for one lamp.
 Thank you for the offer regardless.
Ken Tyler
