POV-Ray : Newsgroups : povray.advanced-users : Q: Advanced Server Time
24 Feb 2025 22:34:59 EST (-0500)
  Q: Advanced (Message 1 to 10 of 13)
Subject: Q: Advanced
Date: 18 Apr 1999 00:05:58
Message: <37194AB7.22B37382@pacbell.net>
When designing macros I have seen occassions where the macro was
specified like this example shows:
 #macro Pattern ()
      granite
        color_map{
                  [0.5000 rgb 0]
                  [0.5001 rgb 1]
            warp { turbulence .03 lambda 1.4 omega 2.0 octaves 5 }
       translate z*3
    scale <2, .5, 2>
 Note the absence of any identifiers inside the macro parenthesis ( )
 This was later used in a media statement as a density pattern.
  My question then is this. Why go through the trouble of making a macro
with no customizable attributes, for a one time use, when is would seem to
me that a simple #declared density would serve the same purpose.
  From where I sit there is no real difference from the above example
and the one that follows.
 #declare Pattern =
  density {
      granite
        color_map{
                  [0.5000 rgb 0]
                  [0.5001 rgb 1]
       translate z*3
    scale <2, .5, 2>
  Would they not function the same way and is there anything to suggest
that the macro offers any advantage the way it is illustrated above ?
Ken
mailto://tylereng@pacbell.net
Subject: Re: Q: Advanced
Date: 18 Apr 1999 00:17:42
Message: <371941A7.B9834CB7@panama.phoenix.net>
I see it as a matter of taste and style, not really any advantage one has over
another. But, I suppose the logical benefit would be that instead of writing
"density {MyDensity}", you just write "MyDensity()" saving a whole 8
characters. At least that's the only reason I see for it.
Date: 18 Apr 1999 05:57:43
Message: <37199e87.0@news.povray.org>
Semantically I don't see a difference either.
Is there a difference in which one parses faster?
Johannes.
Date: 18 Apr 1999 06:02:39
Message: <37199E53.73A88A26@pacbell.net>
> Johannes.
Untested. No data available.
Ken Tyler
Subject: Re: Advanced
Date: 18 Apr 1999 09:04:20
Message: <3719ca44.0@news.povray.org>
The reason would be that you can use this in a pigment or a density, whereas
by #declaring you would be restricted to one of the two.
You can't do this:
#declare Pattern=pigment{...}
media{density{Pattern}}
or vice versa.
Margus
Ken wrote in message <37194AB7.22B37382@pacbell.net>...
> #macro Pattern ()
>      granite
>        color_map{
>                  [0.5000 rgb 0]
>                  [0.5001 rgb 1]
>       translate z*3
>    scale <2, .5, 2>
>  #end
> #declare Pattern =
>  density {
>      granite
>        color_map{
>                  [0.5000 rgb 0]
>                  [0.5001 rgb 1]
>       translate z*3
>    scale <2, .5, 2>
>Ken
Date: 18 Apr 1999 09:21:08
Message: <3719CCD8.B56BD009@pacbell.net>
> You can't do this:
> or vice versa.
> Margus
 I will buy your argument where disallowed functions are concerned and
you will note I carefully avoided that trap with the second example I
provided. The reason I ask though comes from the fact that where I have
been observing the use of this macro peculiarity there have been only
one instance of the macro used in the file. No dual functionality was
apparent so the implementation seems out of place and quite frankly
unnecessary as well.
  Thank you for pointing out the potential duality for this and it is
worthy of taking note of for future use.
Ken Tyler
Date: 18 Apr 1999 10:20:42
Message: <3719dc2a.0@news.povray.org>
Well, it's the only argument I have. I suspect #macro is somewhat slower
than #declare. But since this is an issue in only some extreme cases, it
probably boils down to a matter of taste. Both give the same result with
roughly the same amount of typing, plus #macro has some added flexibility.
Perhaps the author made test renders with pigment instead of media. But this
is just unfounded speculation.
Margus
Ken wrote in message <3719CCD8.B56BD009@pacbell.net>...
>Ken Tyler
Date: 18 Apr 1999 13:15:13
Message: <3719E593.4AF06868@bahnhof.se>
THe #declare _should_ parse faster, since there is no need to jump in the file.
I won't stand for it, and if you ask me, i wasn't sending this message :-)
I think there is a memory-difference as well, esp. when using several objects
with the same density(in this case)
> Johannes.
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 18 Apr 1999 19:16:08
Message: <371e5871.140247331@news.povray.org>
Hope I'm an advanced user...
I think so too.  Also, the #macro version actually has to read the
entire macro declaration once when the macro is first declared
(looking for the #end) as well as when it's invoked.
None that I know of.  In fact, the macro version might use slightly
less memory, but in either case it's a constant amount of memory used
and it won't grow if you use the declared object or macro more than
once.
Date: 18 Apr 1999 19:16:35
Message: <371a59c3.0@news.povray.org>
well /\/\y "/\/\" key is knacked at the /\/\oment so personally i think
#declare is definatly faster for /\/\e.
(sorry couldn't help /\/\yself :)
Margus Ramst wrote in message <3719dc2a.0@news.povray.org>...
this
