POV-Ray : Newsgroups : povray.advanced-users : Q: Advanced Server Time
27 May 2026 18:59:40 EDT (-0400)
  Q: Advanced (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Q: Advanced
Date: 18 Apr 1999 06:02:39
Message: <37199E53.73A88A26@pacbell.net>
Johannes Hubert wrote:
> Semantically I don't see a difference either.
> Is there a difference in which one parses faster?
> Johannes.
Untested. No data available.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Advanced
Date: 18 Apr 1999 09:04:20
Message: <3719ca44.0@news.povray.org>
The reason would be that you can use this in a pigment or a density, whereas
by #declaring you would be restricted to one of the two.
You can't do this:
#declare Pattern=pigment{...}
media{density{Pattern}}
or vice versa.
Margus
Ken wrote in message <37194AB7.22B37382@pacbell.net>...
>When designing macros I have seen occassions where the macro was
>specified like this example shows:
> #macro Pattern ()
>      granite
>        color_map{
>                  [0.5000 rgb 0]
>                  [0.5001 rgb 1]
>            warp { turbulence .03 lambda 1.4 omega 2.0 octaves 5 }
>       translate z*3
>    scale <2, .5, 2>
>  #end
> Note the absence of any identifiers inside the macro parenthesis ( )
> This was later used in a media statement as a density pattern.
>  My question then is this. Why go through the trouble of making a macro
>with no customizable attributes, for a one time use, when is would seem to
>me that a simple #declared density would serve the same purpose.
>  From where I sit there is no real difference from the above example
>and the one that follows.
> #declare Pattern =
>  density {
>      granite
>        color_map{
>                  [0.5000 rgb 0]
>                  [0.5001 rgb 1]
>       translate z*3
>    scale <2, .5, 2>
>  Would they not function the same way and is there anything to suggest
>that the macro offers any advantage the way it is illustrated above ?
>Ken
Date: 18 Apr 1999 09:21:08
Message: <3719CCD8.B56BD009@pacbell.net>
> You can't do this:
> or vice versa.
> Margus
 I will buy your argument where disallowed functions are concerned and
you will note I carefully avoided that trap with the second example I
provided. The reason I ask though comes from the fact that where I have
been observing the use of this macro peculiarity there have been only
one instance of the macro used in the file. No dual functionality was
apparent so the implementation seems out of place and quite frankly
unnecessary as well.
  Thank you for pointing out the potential duality for this and it is
worthy of taking note of for future use.
Ken Tyler
Date: 18 Apr 1999 10:20:42
Message: <3719dc2a.0@news.povray.org>
Well, it's the only argument I have. I suspect #macro is somewhat slower
than #declare. But since this is an issue in only some extreme cases, it
probably boils down to a matter of taste. Both give the same result with
roughly the same amount of typing, plus #macro has some added flexibility.
Perhaps the author made test renders with pigment instead of media. But this
is just unfounded speculation.
Margus
Ken wrote in message <3719CCD8.B56BD009@pacbell.net>...
>Ken Tyler
Date: 18 Apr 1999 13:15:13
Message: <3719E593.4AF06868@bahnhof.se>
THe #declare _should_ parse faster, since there is no need to jump in the file.
I won't stand for it, and if you ask me, i wasn't sending this message :-)
I think there is a memory-difference as well, esp. when using several objects
with the same density(in this case)
> Johannes.
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 18 Apr 1999 19:16:08
Message: <371e5871.140247331@news.povray.org>
Hope I'm an advanced user...
I think so too.  Also, the #macro version actually has to read the
entire macro declaration once when the macro is first declared
(looking for the #end) as well as when it's invoked.
None that I know of.  In fact, the macro version might use slightly
less memory, but in either case it's a constant amount of memory used
and it won't grow if you use the declared object or macro more than
once.
Date: 18 Apr 1999 19:16:35
Message: <371a59c3.0@news.povray.org>
well /\/\y "/\/\" key is knacked at the /\/\oment so personally i think
#declare is definatly faster for /\/\e.
(sorry couldn't help /\/\yself :)
Margus Ramst wrote in message <3719dc2a.0@news.povray.org>...
this
Date: 19 Apr 1999 05:23:56
Message: <371ae81c.0@news.povray.org>
Rick wrote in message <371a59c3.0@news.povray.org>...
[snip]
>/\/\oment
[snip]
So I guess you got that "m" with cut-and-paste from somewhere else, hmm?
Johannes,
Date: 24 Apr 1999 16:25:02
Message: <37221A84.CB8E08D2@merlin.net.au>
> > You can't do this:
> > or vice versa.
> > Margus
> Ken Tyler
Also note the difference if you use something like rand() inside the
macro/#declare.
If you think you might do this at some time in the future, then you'd
best decide at the start how you want it to behave.
PoD.
P.S. I know this response took a while, I've been wandering around in
Linux newbie land for the last few weeks :)
Date: 26 Apr 1999 00:10:18
Message: <3723D92A.E7426A24@ij.net>
	Speaking as one who has advanced beyond the BS of compiler
salesmen ... :)
	Whatever it is optimized for is what it is fastest at. Rule one,
optimize for the benchmark tests.
	That is why the benchmark tests are so diverse.
