POV-Ray : Newsgroups : povray.advanced-users : Q: Advanced Server Time
27 May 2026 19:00:23 EDT (-0400)
  Q: Advanced (Message 11 to 13 of 13)
Subject: Re: Advanced
Date: 19 Apr 1999 05:23:56
Message: <371ae81c.0@news.povray.org>
Rick wrote in message <371a59c3.0@news.povray.org>...
[snip]
>/\/\oment
[snip]
So I guess you got that "m" with cut-and-paste from somewhere else, hmm?
Johannes,
Date: 24 Apr 1999 16:25:02
Message: <37221A84.CB8E08D2@merlin.net.au>
Ken wrote:
> Margus Ramst wrote:
> > The reason would be that you can use this in a pigment or a density, whereas
> > by #declaring you would be restricted to one of the two.
> > You can't do this:
> > #declare Pattern=pigment{...}
> > media{density{Pattern}}
> > or vice versa.
> > Margus
>  I will buy your argument where disallowed functions are concerned and
> you will note I carefully avoided that trap with the second example I
> provided. The reason I ask though comes from the fact that where I have
> been observing the use of this macro peculiarity there have been only
> one instance of the macro used in the file. No dual functionality was
> apparent so the implementation seems out of place and quite frankly
> unnecessary as well.
>   Thank you for pointing out the potential duality for this and it is
> worthy of taking note of for future use.
> Ken Tyler
Also note the difference if you use something like rand() inside the
macro/#declare.
If you think you might do this at some time in the future, then you'd
best decide at the start how you want it to behave.
PoD.
P.S. I know this response took a while, I've been wandering around in
Linux newbie land for the last few weeks :)
Subject: Re: Q: Advanced
Date: 26 Apr 1999 00:10:18
Message: <3723D92A.E7426A24@ij.net>
> THe #declare _should_ parse faster, since there is no need to jump in the file.
> I won't stand for it, and if you ask me, i wasn't sending this message :-)
> I think there is a memory-difference as well, esp. when using several objects
> with the same density(in this case)
	Speaking as one who has advanced beyond the BS of compiler
salesmen ... :)
	Whatever it is optimized for is what it is fastest at. Rule one,
optimize for the benchmark tests.
	That is why the benchmark tests are so diverse.
