POV-Ray : Newsgroups : povray.advanced-users : rayshade -> povray? Server Time
12 Jan 2025 14:31:43 EST (-0500)
  rayshade -> povray? (Message 1 to 3 of 3)
Subject: rayshade -> povray?
Date: 1 May 2002 20:06:47
Message: <1514098.ErgHkdLfG0@3-e.net>
Is this possible?
I found a great L-system program for linux called svlab but it exports
rayshade or GLS (Open GL stream) files.
Are there converter or tricks for getting these files into POV?
Subject: Re: rayshade -> povray?
Date: 2 May 2002 20:41:01
Message: <3847553.dgrriASvYE@3-e.net>
Never mind, the author of T3DLIB sent me the source code which compiles on
NT or Linux. Glenn has been very helpful and I will need to clear any
copyright issue with him before sharing the end result (code). It has
.ray->.pov I just need to work out how to use it, or mod the code so that
it works with rayshade 4 files correctly.
T3DLIB was around 5-10 years ago.
Daniel Matthews wrote:
> Is this possible?
Your connection failed because: We had to turn off that service to comply
with the CDA Bill.
Date: 3 May 2002 02:50:57
Message: <1186310.GsshdfAi7K@3-e.net>
DOH! T3DLIB won't work after all!!
So I still need a .ray to .pov converter.
Any ideas? Would a patch to POVRAY that used the parser out of rayshade 4
do the trick. Is this sort of this possible AND allowed?
BTW has anyone else looked at svlab?
http://pages.cpsc.ucalgary.ca/~pwp/bmv/vlab-for-linux/html-docs/
>> Is this possible?
> with the CDA Bill.
Your connection failed because: non-redundant fan failure
