POV-Ray : Newsgroups : povray.advanced-users : passing variable to macro for use in #for statement : Re: passing variable to macro for use in #for statement Server Time: 24 May 2019 01:45:06 GMT
Date: 20 Sep 2018 20:45:01
> Am 20.09.2018 um 20:56 schrieb Kenneth:
> > The even shorter keyword  #elif  (for #elseif) is not mentioned there (even
> > though it works)...
> Actually, no, it doesn't work: That's a mirage. If you examine it more
> carefully, you'll find that the construct only behaves as expected if...
Oh, sorry. I didn't thoroughly test the  #elif  keyword; I used your macro
construct as-is (basically), and it just *happened* to work in my case, or
appeared to.
Caveats noted!!
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
