POV-Ray : Newsgroups : povray.advanced-users : Normal vector deformation : Re: Normal vector deformation Server Time: 20 Mar 2010 21:16:24 GMT
Date: 14 Jan 2001 03:42:35
In article <3A61158D.9D409B1B@online.no>, Tor Olav Kristensen
<torolavk [at] onlineno> wrote:
> Hmmm ... Are you sure about this ?
The normal to the -x side of a box is -x. The top of the box is then
sheared +x so the -x and +x faces are at a 45 degree angle...but points
still remain in the same xz plane as they were before, the -y and +y
faces remain perpendicular to the y axis. The normal should be at a 45
degree angle now, <-sqrt(2)/2, sqrt(2)/2, 0> to be precise, but since
the two sample points were in the same xz plane, their position relative
to each other is the same, and the normal is still -x.
> If so, then how would you define a
> normal of a surface at a given point ?
The vector perpendicular to the surface at that point.
Christopher James Huff
TAG: chris.huff [at] tagpovrayorg, http://tag.povray.org/
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
