POV-Ray : Newsgroups : povray.advanced-users : With all the talk of color, HCY : Re: With all the talk of color, HCY Server Time: 22 Jul 2019 22:56:13 GMT
Date: 26 Nov 2016 21:30:10
On 11/26/2016 1:23 PM, [GDS|Entropy] wrote:
> Here is the code I use for working with HCY in Processing, I know this
> isn't SDL but I do not at present have time to convert it and I thought
> someone might find it useful.
> For me it is wonderful because using only one array I can get the range and
> intensity of colors I want far more easily than I can with other models, I
> just pipe it into H and set C and Y to the value below...though it really
> gets interesting when you plug other arrays into Y in particular. That
> works out very well for 2 chemical RD systems obviously, which is what I
> use it for.
> //    H Varies
> //    C = 100 [gives full brightness]
> //    Y = 75 or varies. [gives full saturation]
> public color HCYtoRGB(float h, float c, float y)
>     final PVector REC709y = new PVector(0.2126, 0.7152, 0.0722);
>     PVector hcy = new PVector(h, c, y);
>     float r = constrain(abs(6 * h - 3) - 1, 0, 1);
>     float g = constrain(2 - abs(6 * h - 2), 0, 1);
>     float b = constrain(2 - abs(6 * h - 4), 0, 1);
>     PVector rgb = new PVector(r, g, b);
>     float z = rgb.dot(REC709y);
>     if (z >= hcy.z)
>         hcy.y *= hcy.z / z;
>     else if (z < 1)
>         hcy.y *= (1 - hcy.z) / (1 - z);
>     rgb.sub(z, z, z);
>     rgb.mult(hcy.y);
>     rgb.add(hcy.z, hcy.z, hcy.z);
>     rgb.mult(255);
>     return color(rgb.x, rgb.y, rgb.z);
> I hope this is useful to someone. Have fun. :)
> I have a render (Processing not Pov) of the predator-prey RD system by
> Sirohi et. al. 2015 which will go up on Flickr soon which uses this.
> Ian
I have never heard of HCY. Is there any documentation about it?
Mike
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
