POV-Ray : Newsgroups : povray.advanced-users : depth map? : Re: depth map? Server Time: 19 Mar 2010 06:01:04 GMT
  Re: depth map?
Date: 23 Mar 2009 15:06:55
"Sidney Cadot" <sidney.cadot [at] jigsawnl> wrote in message
news:web.49c79d64a563150ecb94416e0@news.povray.org...
> Dear all,
> For a technical project I am doing concerning stereo reconstruction, it
> would be
> helpful to be able to have access to the depth (z) coordinate of the
> directly
> visible object at each pixel in the rendered image.
> Ideally, I would have a file that gives (IMAGEHEIGHT x IMAGEWIDTH)
> floating
> point numbers (IEEE-754 format), each giving the projected "z" value for
> the
> corresponding pixel (or "infinity" if there is no object in the eye->pixel
> ray
> path).
> Has something like this perhaps been done before? If not, how difficult
> would it
> be to add this myself (I am proficient in C, but I have never looked at
> the
> source code of POV-Ray) ?
> Best regards, Sidney
I don't think you'd need to necessarily get into the source code to do this.
If you can build the contents of the scene into a single CSG union assigned
to an identifier in POV-Ray SDL, then you should be able to get this data
using a bit of maths and the POV-Ray 'trace' function. You can loop through
the pixel positions on the image plane tracing rays out from the camera
position to retrieve the position at which the traced rays hit the union
object. You can write the floats out using the #fopen, #write and #fclose
directives.
Chris B.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
