POV-Ray : Newsgroups : moray.win : Geometry in Moray... Server Time
16 Mar 2026 07:58:05 EDT (-0400)
  Geometry in Moray... (Message 1 to 6 of 6)
Subject: Geometry in Moray...
Date: 11 Aug 2006 10:30:00
Message: <web.44dc9421a744a04d4f032e0d0@news.povray.org>
I need to create a perfectly triangular object (glass plate) in Moray and
can't figure out how to easily do so. I have gone throught the doc's I can
find but to no avail...yes I am a nubi....
Subject: Re: Geometry in Moray...
Date: 11 Aug 2006 10:42:40
Message: <44dc9760@news.povray.org>
news:web.44dc9421a744a04d4f032e0d0@news.povray.org...
What do you call "perfectly " triangular? any 3 coplanar vertice polygone
makes a perfect triangle.
You could try with a translational sweep with linear interpolation...
Marc
Date: 13 Aug 2006 07:25:01
Message: <web.44df0b59366ff4524f032e0d0@news.povray.org>
please forgive my embarassing ignorance but I'm (as I stated in my first
post) a new comer to this software and to 3d modling in general. I don't
understand how to  create a simple triangle object in this program. there
are cubes and spheres but nothing triangular to start with.
> Marc
Date: 13 Aug 2006 11:06:02
Message: <44df3fda$1@news.povray.org>
> I don't
Starting with a new scene, you can create a 'Translational Sweep'. On the
right hand side select the 'Edit' tab. Useing the top viewport you can
left/click/drag points around, or while holding down the shift key, select a
point and enter the values in the 'Coordinates of Selected Points' section.
If  you need to have a mesh object, you can convert this shape into a mesh
with Edit/Convert to Mesh.
Hope this helps.
Date: 14 Aug 2006 02:25:06
Message: <44e01742@news.povray.org>
web.44df0b59366ff4524f032e0d0@news.povray.org...
Apologizes if my  question sounded rude.
I just wanted to know if you meant a particular triangle or any one. :-)
My answer was  unclear as well, but see Stephen's
Marc
Date: 15 Aug 2006 11:34:45
Message: <jlp3e21omj0h89rnf178f744a2vtf3jgnj@4ax.com>
Hi tptorpey, you recently wrote in moray.win:
Glad to see you made it here :-)
Moray is primarily a Constructive Solid Geometry modeller. Note the
'Solid' part :-) A triangle is not solid and so that's why some of the
suggestions (including mine) mentioned a translational sweep, which is
kind of a three dimensional triangle. Well, it starts out as a
quadrilateral, but if you delete one of the control points, it'll be a
triangle.
That said, you can work with a single triangle in the mesh editor.
Best way to do that is this:
Create > Plane
Edit > Convert To Mesh
Click on Edit tab at the top of the right sidebar
Go to Edge mode (press D)
Select any edge by Shift-dragging around a blue dot in the middle of
the edge.
Click on Split (under Edge operations), or Press S
Switch for Face mode (press F)
Shift-Select (hold Shift while clicking on them) the two smaller
triangles
Press Delete
Answer Yes to deleting the orphaned vertices.
Voila, triangle.
I realize this is a bit convoluted, just to get a triangle, but as I
mentioned Moray's modelling paradigm is not primarily based on a
triangle/mesh modeller.
Cheers,
- Lutz
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
