POV-Ray : Newsgroups : moray.win : Cannot start POV-Ray. Please start POV-Ray manually and try again. Server Time
17 Nov 2025 00:08:56 EST (-0500)
  Cannot start POV-Ray. Please start POV-Ray manually and try again. (Message 1 to 6 of 6)
Subject: Cannot start POV-Ray. Please start POV-Ray manually and try again.
Date: 16 Nov 2005 09:45:00
Message: <web.437b453e952fc842f5fba6ef0@news.povray.org>
Hello.
I just installed Moray 3.5. POV-Ray 3.6.1 was already installed and now the
option GUI-Extensions->Moray Communication DLL->Enabled is checked 'on'.
Here are my settings (I changed nothing to default installs):
a) In Moray's rendering otpions, all paths to POV-Ray are OK:
d:\Program Files\Moray For Windows\POVSCN\
d:\Program Files\POV-Ray for Windows v3.6\bin\PVEngine.exe
d:\Program Files\Moray For Windows\MorayPOV.INC
b) I have MorayCtrl.dll in d:\Program Files\Moray For Windows\ as expected.
the vesion is 1.30.0.0.
c) In PVENGINE.ini, I have
[GUIExtensions]
UseExtensions=1
ExtDll15=d:Program FilesMoray For WindowsMorayCtrl.DLL
When POV is not lauched, F9 on Moray launches POV and the render is OK. But,
if I try F9 again, everything blocks, POV and Moray. I get an error box
with
"Cannot start POV-Ray. Please start POV-Ray manually and try again."
If I launch POV before rendering, I have the same.
I tried many things, including re-booting my machine, but nuts ....
I think I made something wrong, because I cannot imagine it does not work.
If you encountered the same problem, please give me the trick! Though it is
less convenient, I can export the model to POV, but I would like to render
the material library. And I also would like to be like all the others....
Regards.
Subject: Re: Cannot start POV-Ray. Please start POV-Ray manually and try again.
Date: 16 Nov 2005 10:03:44
Message: <437b4a50$1@news.povray.org>
Moray 3.5 doesn't play nicely with POV 3.6.x
Tim Cook
Version: 3.12
Date: 17 Nov 2005 03:17:41
Message: <437c3ca5$1@news.povray.org>
message de news:web.437b453e952fc842f5fba6ef0@news.povray.org...
is
> Regards.
You did nothing wrong but as replied Tim, there is a GUI issue between Moray
and POV 3.6
You can have POV 3.5 installed in a separate folder and use it as a test
version as it works flawless.
ftp://ftp.povray.org/pub/povray/Old-Versions/Official-3.5/
Marc
Date: 4 Oct 2010 04:35:01
Message: <web.4ca9900cd96a259b561919e10@news.povray.org>
This line is missing the forward \ \ if thats how you actually put it , that
would be why it didnt work .
I had the same problem moray cannot start povray ,
I added the line
ExtDll15=C:\Program Files\Moray For Windows\MorayCtrl.DLL to PVENGINE.ini and
povray 3.62 works perfectly.
I know this is an old post but for clarity it does indeed work .
Mike G
Date: 5 Jun 2011 14:45:00
Message: <web.4debce98d96a259b22556d3f0@news.povray.org>
> I added the line
> Mike G
Aaahhhh!!
I gonna be crazy!
I have PovRay 3.5 / 3.6 /3.7 beta and Moray.
I used Moray and PovRay,
in the begining impossible to make Moray
and PovRay 3.6 and 3.7 working,
So I configured Moray to work with PovRay 3.5,
it work perfectly
few days,
and suddenly, after a reboot,
I don't know why
I have the same problem as described above.
Sometime the first render work, but the second wont (?!)
and sometime, nothing want to work...
Since, impossible to make something
between Moray and PovRay.
I tried the solution gave by Mike,
but it's the same,
nothing work.
I mean between Moray and PovRay 3.5 ( or 3.6 and 3.7)
Someone have the explanation and the solution?
Have a nice day,
Date: 6 Jun 2011 15:40:01
Message: <web.4ded2cccd96a259b22556d3f0@news.povray.org>
> > I added the line
> > Mike G
> Hi,
> Aaahhhh!!
> I gonna be crazy!
> it work perfectly
> few days,
> I don't know why
> but it's the same,
> nothing work.
> Have a nice day,
To continu with my adventure,
I desinsalled POVray 3.5
because finally it didnt want to do anything even render alone...(?)
Reinstalled it,
lunched Moray,
Moray, setup it (like in the first time)
and now it works as well,
and surprise,
for the first time now
it render inside moray !
I didnt know that is possible.
Anyway, that trouble finally
permit me to discover that.
btw, I'm under W7 x64.
